Dumblelator clone transformer mounting
I am looking into building a Dumblelator clone and I was wondering if mounting a transformer to the rear wall of a rack 1U chassis would be a problem? Are there certain considerations to take into account mounting it this way?
Re: Dumblelator clone transformer mounting
That is the way the original documented here had its PT mounted. https://ampgarage.com/forum/viewtopic.p ... 69#p140269
I should have mentioned I was planning to install the transformer inside the chassis. The transformer is a Triad R-30X. I would need to find a cover for the transformer I was looking at to mount it on the outside.
Probably ok to use as-is.
