Hi,
Anybody take backside board pictures of they"re #124 builds?
Looking for jumper picks and under board wiring. Some of the board pictures are hard to see through, espeicially the "FET" board.
Thank you, Brian
Pictures of the backsides of the boards....
Re: Pictures of the backsides of the boards....
You can get a good idea from these layouts. Reverse engineer and apply to whatever layout you are using . https://ampgarage.com/forum/viewtopic.p ... t=Bias+fet
Charlie
Thank you, Those are the ones I'm using. The fet board is hard to trace, top left by the pot...
Brian
Brian
All three eyelets at the top left on the FET board are ground, all tied together. The output eyelet only goes to the middle of the pot, the wiper.
so, top three from left to right go to ground, output goes to center post of the pot and 47u cap goes to lower pot?
Just trying to not go poof.......
Brian
Brian
Correct. 4.7uF though.
Yup, 4.7
Thanks all, Brian
Thanks all, Brian
