I’ve found mixed “search” results regarding their ability to handle plate voltages above 400 and the internet seems to have a half dozen data sheets floating around that vary quite a bit - so thought I’d get a consensus amongst other HAD-type builders with more experience.
Any info/insight is appreciated!
Thanks!
Marc
Anybody using 6P3S tubes in D-style amps?
- Raoul Duke
Re: Anybody using 6P3S tubes in D-style amps?
me,
on 400-420vdc you can use -E version, 6P3S-E,
- Raoul Duke
Thanks, that seems to be the consensus of all the info I'm seeing.
Marc
