Steel String Singer 150w Transformers
Does anyone have any leads where to find a power transformer for 150w KT88 SSS build? If not, what specs I should send to a transformer company?
Thank you!
Jay K.
Thank you!
Jay K.
Re: Steel String Singer 150w Transformers
Hammond makes a 290s2z sunn 2000 replacement transformer . 780 vct @ 400ma HT. 8amp heater current . -55 bias tap 5v 4amp tap. Those amps were conservatively rated at 120w clean. If I recall correctly 4x6550 sss have been measured around 135w clean output. Someone else who knows better should be able to chime in and confirm or deny
Charlie
That’ll definitely get me in the ballpark! Thank you!!
Output transformer should be 2k2, with a good frequency reponse like a dynaco a451
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Hello --
Another solid (perhaps better) option from the Hammond catalog is the 378CX; with slightly higher secondary, bunch more current, and no winding wasted on 5V rectifier.
Did they "can" it for you like the Dynaco originals?
- Colossal
Were the specs the same as the Dynaco?
Also, thank you all for the suggestions and input! Greatly appreciated!
Nice . Bias winding is only 6A instead of 8A…probably works fine still , we all know 183 Twin PT can handle the extra cutrent draw from EL34….conservative ratings
Charlie
Filament and yes, it's a bit less than desirable, but likely cool regardless due to Hammond's rating over spec. As spec'ed a touch overloaded and nothing really left for preamp and PI assuming a quad of larger KT series heaters. Suggest KT77 would work well, or 6CA7EH; both are pretty robust. A few minutes doing some sums are in order before putting out any purchase orders.WhopperPlate wrote: ↑Mon Feb 26, 2024 7:37 pmNice . Bias winding is only 6A instead of 8A…probably works fine still , we all know 183 Twin PT can handle the extra cutrent draw from EL34….conservative ratings
Precisely, meant to say filament , thanks for correctingdidit wrote: ↑Mon Feb 26, 2024 9:03 pmFilament and yes, it's a bit less than desirable, but likely cool regardless due to Hammond's rating over spec. As spec'ed a touch overloaded and nothing really left for preamp and PI assuming a quad of larger KT series heaters. Suggest KT77 would work well, or 6CA7EH; both are pretty robust. A few minutes doing some sums are in order before putting out any purchase orders.WhopperPlate wrote: ↑Mon Feb 26, 2024 7:37 pmNice . Bias winding is only 6A instead of 8A…probably works fine still , we all know 183 Twin PT can handle the extra cutrent draw from EL34….conservative ratings
Charlie
How about this PT: https://www.tube-town.net/ttstore/en/to ... h100r.html
Pri: 230 V (blau-rot/blue-red)
Sec 1: 330 V @ 0,5 A (rot-rot / red-red)
Sec 2: 15 V @ 1,5 A (weiss-schwarz / white - black)
Sec 3: 15 V @ 1,5 A ( schwarz - weiss ( black - white)
Sec 4: 3,4 V @ 9 A ( blau - grau / blue - grey)
Sec 5: 3,4 V @ 9,0 A (grau - blau / grey - blue)
Sec 6: 100 V @ 0,01 A (orange - orange)
330+15+15VAC=360VAC
This should give 500VDC at idle (my experience with another of their PTs in this series is that unloaded voltages read higher than the spec'ed nominal voltages. 330VAC gives me 460VDC+ at idle (with a 75ma current draw roughly)
330+15+15VAC=360VAC
4x12" w/H75s
4x12" w/H75s
