Hi everyone
So i changed the middle pot to a A 10K and removed the 6.8k to ground (just ground). Still the EQ Settings with treble middle bass, seemed not to match. I could turn the knobs as much as i wanted - i did not feel AB763 like.
My critical test is using only a XOTIC RC booster in front of the amp. With the changes above the rc sounded harsh and fuzzy - in no way i had it like in front of my super, with that nice tiny chrunch sound.
So i figured since the original Vibroverb also had no middle i have to check further how a blackface with Middle Pot is build. The one difference is, that there is a 0.022uf cap at the tonestack. So i replaced the 0.047uf with a 0.022uf - and there we go.
No it feels like a Blackface with middle and i can now mix treble middle and bass in a way i expect it from a blackface. Also my RC test is now just as it is on any blackface not only AB763.
Based on my research i think almost all blackface without a 10K Middle hat a 0.047uf at tonestack (Princeton, Delxue, Vibroverb) but the once with a middle (Super) had a 0.022uf.
Greetings Reto
Blackvibe 6L6 Strange behavior on tone pots
Re: Blackvibe 6L6 Strange behavior on tone pots
If your looking for any mid boost with aFender type tonestack the only way to get any of that or even get a flat response out of it is to turn the volume way up, crank full up the middle and set the bass and treble very low.
Thanks for the update. Makes sense.retodellatorre wrote: ↑Thu Apr 25, 2024 8:07 am So i changed the middle pot to a A 10K and removed the 6.8k to ground (just ground)... ... So i replaced the 0.047uf with a 0.022uf - and there we go.
