AX-84 data sources?
AX-84 data sources?
Post by Mark »
I remember the AX-84 site having great data on building their amps. I recall there are pictures of the boards and the boards wired into the chassis. I have been searching quite a bit but I just can’t locate these files.
Has anyone saved or found these diagrams?
This is some of the relevant info I found.
http://paulamps.com/HOLayout.html
http://www.egodeath.com/ax84.htm
statorvane
Re: AX-84 data sources?
Post by statorvane »
Nyberg's website has some photos and audio demos of the High Octane and November AX8 projects: http://www.cs.cmu.edu/~ehn/ax84/#filter
Post by Mark »
statorvane wrote: Mon Aug 05, 2024 8:41 am Nyberg's website has some photos and audio demos of the High Octane and November AX8 projects: http://www.cs.cmu.edu/~ehn/ax84/#filter
Thanks for that link, it’s quite helpful.
I find the P1 amp to be a little strange, a lot of gain is lost via the treble peaking network after the volume control and the second stage has to drive the tone controls. I found with the master volume on half the gain was rather lacklustre. The amp only sounded good when both the preamp and master volume were up full and I was using a guitar with an overwound humbucker.
ax84_P1 Ver 11.pdf
pullshocks
Post by pullshocks »
The AX 84 forum was re-homed to the site below. Very little current activity, mostly bots. A lot of old content is preserved there, but accessing it via the search window was problematic last time I tried
https://perpetualinnovation.us/MyBBDir/
Many but not necessarily all of the AX84 documents can be found here
https://web.archive.org/web/20190625051 ... .ax84.com/
