BAXANDALL EQ Question....
zozoe
Post by zozoe »
Greetings again~ I've been wondering why my Ampeg GU12's don't rock nearly as well as my AC12's.... My GU's are both wonderfully clean, but NOWHERE as 'Stones'y as the AC's once its NFB is clipped.
THEN, I just now caught a YT video, comparing the 2 amp models, & the only major diff was that the AC's had a NFB loop whilst the newer GU's removed it, BUT the guy furthur explains how ''the 2-band (treb/bass) Baxandall eq curcuit on the GU's has less gain in the front end than the single Tone circuit on the AC 's, MUCH less!!" AHA!!
Is there anything, including totally altering or replacing the Baxandall, in order to re'gain' that lost gain factor that truly disappoints & perhaps is why the GU doesn't kick arse like the AC's (w/NFB clipped!)??
Many thanks~
Stevem
Re: BAXANDALL EQ Question....
Post by Stevem »
So why are you looking to have two amps that can do the same thing.
zozoe
Post by zozoe »
Backup.....
about my Baxandall question?
TUBEDUDE
Post by TUBEDUDE »
It does load the signal much harder than.a single tone control, ie. high filter.
Maybe you could try a tilt control to.get what you need and preserve gain.
zozoe
Post by zozoe »
TUBEDUDE wrote: Tue Oct 22, 2024 10:39 pm It does load the signal much harder than.a single tone control, ie. high filter.
Is it a difficult, overly invasive conversion for a tech (not me) who knows his stuff? Tilt Control?? Not familiar..
Thnx, Kenny ॐ💃🪕
Bergheim
Post by Bergheim »
zozoe wrote: Wed Oct 23, 2024 3:24 am
Thnx, Kenny ॐ💃🪕
A tech who knows his stuff should be able to do this without any problem. The tilt control is a one knob control, so it'll leave you with a unused hole in the front panel. I'd rather try to increase the gain downstream, for example bypassing the phase inverter driver stage cathode resistor (R25), or decreasing the reverb mixing resistor (R23).
lonote
Post by lonote »
zozoe wrote: Tue Oct 22, 2024 2:33 am I've been wondering why my Ampeg GU12's don't rock nearly as well as my AC12's.... My GU's are both wonderfully clean, but NOWHERE as 'Stones'y as the AC's once its NFB is clipped.
I can't offer any insights other than the AC has the much simpler tone control. But I am not familiar with either of those amps & only pulled up the schematics due to your query.
I have never built a James-style tonestack, but I am wondering if lifting the tonestack ground reference would have a similar bypass effect, as it does with the Fender TS..? I know when the ground is lifted with the Fender circuit, the tone stack is minimized/nearly bypassed & it passes more signal onto the next stage. Might be what you are looking for? Maybe the more knowledgeable will weigh in.
But, they are both pretty interesting amps & as you play through them both, I had some questions, as I might borrow some ideas from them.
Do you find the AC tone circuit pretty usable for guitar? (I think it was actually meant to be an accordion amp) Do you like the reverb? Typical spring tank? (just says "echo unit" on schematic)
Thanks in advance
Stevem
Post by Stevem »
On Ampeg schematics they call the reverb tank a echo unit which to me is not quite as bad as Fender for many decades now calling tremolo a Vibrato function right on the amps front panel.
