New build New question
studiodunn
Post by studiodunn »
*New pics Below*
[original post]
I Just finished this Express build and everything was great from the first firing....well, almost everything.
Plate to cathode is 401v, with -33v @ bias. When i try to bias el34s to around 40ma with the MV opened up, the amp gets unhappy. rolling the MV back stops the problem.
This is a pretty straight copy of Kelly, with a few tweaks from other variants but nothing I would consider out of spec.
https://youtube.com/shorts/7Sx81KkdQl8?feature=share
Re: New build bias / PPIMV weirdness
Disconnect NFB loop from OT tap. How does this affect the issue?
studiodunn
xtian wrote: Mon Dec 09, 2024 10:06 pm Disconnect NFB loop from OT tap. How does this affect the issue?
That makes the issue come on faster, so worst
So you've got some major instability, I guess, and since you've got a non-standard layout, lead dress might be the issue. Oh yeah, I see one major no-no: your green OT primary (output tube socket pin 3) is touching the phase inverter grid wire (pin 7, white wire).
studiodunn
xtian wrote: Mon Dec 09, 2024 10:49 pm So you've got some major instability, I guess, and since you've got a non-standard layout, lead dress might be the issue. Oh yeah, I see one major no-no: your green OT primary (output tube socket pin 3) is touching the phase inverter grid wire (pin 7, white wire).
Thanks xtian!
studiodunn
This is a layout mistake on my part. The original layout did not have a MV and the grid stoppers were on the board. I put the ppimv in and forgot to add new resistors off board. Dumb mistake on my part.
studiodunn
Got the amp/cabinet finished and she screams. I put the HV windings on a switch and love running a pair of 6k6's in it. They give up a very vintage growl that I love in this circuit.
I added a 6 position switch (shift) that chooses the TS coupling cap 10p through 1000p. This does a really cool job of shifting the mid frequency and letting the amp be cleaner and fatter.
Cheers and Happy New Years to Y'all.
Littlewyan
Re: New build fixed and finished
Post by Littlewyan »
Looks really cool! Nice work! Love the cabinet.
statorvane
Post by statorvane »
+1 8)
studiodunn
Re: New build fixed and finished - NEW Question
Quick question for the masses - has anyone experienced there (in this case Express) amp just sounding better with an impedance mismatch?
I have been playing the amp allot through several cabinets and plugged into the cabinet I had mainly been playing the amp through, and it just sounded better. It's a pure 64 ported 1x12 loaded with a 12K-85.
The amp sounded so much better, i looked to see what might have changed and sure enough, the amp was set to 8ohm and the cab is 16. Is this just a combination of small variations in the circuit and parts that would make the mismatch work better?
