Please check these voltage measurements..
odourboy
Post by odourboy »
On my 100W HRM 'Funk Build' (with BM PI values). Just completed construction and now tuning and tweaking. It sounds pretty friggin' good, but please let me know if you see anything that looks out of whack. I went through the amp and measured the following voltage levels:
AC line: 122VAC
B+1: 452
B+2: 451
B+3: 423
B+4: 335
B+5: 316
V1a Plate: 185 Cathode: 1.91
V1b Plate: 190 Cathode: 1.80
V2a Plate: 205 Cathode: 1.86
V2b Plate: 208 Cathode: 1.86
PI Upper Plate: 261 Lower Plate: 255
cathodes: 44, R junction 42
Bias: -49V; ~35mA on each 6L6GC
Cheers! Brian
heisthl
Re: Please check these voltage measurements..
Post by heisthl »
odourboy wrote:On my 100W HRM 'Funk Build' (with BM PI values). Just completed construction and now tuning and tweaking. It sounds pretty friggin' good, but please let me know if you see anything that looks out of whack. I went through the amp and measured the following voltage levels:
AC line: 122VAC
B+1: 452
B+2: 451
B+3: 423
B+4: 335
B+5: 316
Cheers! Brian
That's in the same ball park as the BM I posted in the files section:
V1a Plate 184 v1b 189 v2a 203 v2b 216 v3a 266 v3b 260 v3k 39
String 441 439 413 334 302
www.RedPlateAmps.com
odourboy
Post by odourboy »
Same ballpark? Pretty dang close. :D
Excellent! Thanks for checking this heisthl. I presume you're happy with the results of your BM build?!
