Is a 100w marshall plexi replacement OT good for a clone?
massygt6
Post by massygt6 »
Hi!
first of all let me make my best wishes to you all for this new year...
I have the chance to take an hammond 1750u guitar series for a good price...
is a marshall plexi/800 100w replacement with a 1700 ohms primary...is it good for an ODS clone?
thanks...
Max
Hotrod Ford
Re: Is a 100w marshall plexi replacement OT good for a clone?
Post by Hotrod Ford »
yes, great if you build a el34 amp,
it would work with 6l6 but you would preferably want a little higher pri-imp if 6l6 is used, that is if you want to use the correct output impedances to match the speaker
massygt6
Post by massygt6 »
thanks!
I'm gonna use 6l6 by now...and I've got an 8ohm 2x12 cab...el34 on the way ;-)
glasman
Post by glasman »
I have used the 100W marshall iron from Antique in the past and it sounded pretty nice. I even have one d-clone amp here, 100W, that is build with a Sovtek MIG 100 transformer set (550v on plates) that sounds frigging awesome with 6L6's. The MIG tranny measured 2400 p/p. That amp puts out about 110 watts before it goes into clipping.
About 5 miles south of I-94
www.glaswerks.com
massygt6
Post by massygt6 »
glasman wrote:I have used the 100W marshall iron from Antique in the past and it sounded pretty nice. I even have one d-clone amp here, 100W, that is build with a Sovtek MIG 100 transformer set (550v on plates) that sounds frigging awesome with 6L6's. The MIG tranny measured 2400 p/p. That amp puts out about 110 watts before it goes into clipping.
wow, that's awesome...I can only imagine what kind of enormous headroom has that beast...
anyway, the tranny is arriving...i'll keep you informed if you want...
thanks again!
Max
