Why do I have to jumpstart it?
My amp works fine BUT if I put it on standby for a few seconds then take it off standby there is no sound until I jump the PI tube pins 8 and 7. Seconds later there is sound. Any ideas? Thanks!
Re: Why do I have to jumpstart it?
I've no answer, but I'm sure curious to know as to how you discovered the fixandrew wrote: My amp works fine BUT if I put it on standby for a few seconds then take it off standby there is no sound until I jump the PI tube pins 8 and 7. Seconds later there is sound. Any ideas? Thanks!
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
![Idea :idea:](./images/smilies/icon_idea.gif)
What sort of inverter?
Hey! I'ts a copy of a D'Lite 22. I discovered the fix while touching each preamp pin with a screwdriver and accidently touched both pin at once. Maybe I'll install a jumpstart switch on the front panel and call it a "post standby activinator".
Make sure you don't have any cold solder joints anywhere in the circuits leading to pins 6, 7 and 8. That just doesn't sound right!
On the PI tube pin 6(100k side) is 202v pin 1 (82k side) is 339v ----- Any clues here?
- skyboltone
Silly question I kow but have you switched tubes?andrew wrote:On the PI tube pin 6(100k side) is 202v pin 1 (82k side) is 339v ----- Any clues here?
I got the same results with a new tube.
Thanks for the help-it was a cold solder joint at the 1meg,1meg 820r,24k junction!
