odd sound in power amp section
Maybe someone can help me, I was fixing my fender blues deluxe ri and when I was done the amp hummed more and it sounded odd when I plugged directly into the power section. It seemed that all notes were flatter. does anyone have any idea? could it because the phase inverter? thanx
Re: odd sound in power amp section
Not sure I can help but a couple of questions to fill in the blanks.
What was wrong in the first place which needed fixing?
What did you do?
What did you do?
I changed the bright channel and the reverb, also replaced a small input capacitor 47pf off the V3 tubefishy wrote:Not sure I can help but a couple of questions to fill in the blanks.
What did you do?
What do you mean "when I plugged directly into the power section"? Plugged what?blue_dog wrote:Maybe someone can help me, I was fixing my fender blues deluxe ri and when I was done the amp hummed more and it sounded odd when I plugged directly into the power section. It seemed that all notes were flatter. does anyone have any idea? could it because the phase inverter? thanx
Also, you say you changed a 47pf cap; to what? And why?
Found the problem, cold solder joint off a filter cap caused the spongy sound. thanks for the help anyways.
