Rectifier Arc, Bad tube?? help
Fired up my 2 hole rocket with no tubes and checked out voltages @ 122.5vac into a Hammond 370FX 275/0/275 150mA. - heater voltage 7vac Rectifier 5vac was 5.4vac - primary was 280vac to grnd. on both taps .after installing my start up tubes and powering it back up , 20 -30 seconds later it takes out the fuse (3a). No smoke , and nothing is hot . I had used an old fuse holder on this build so I suspected that . No , a second fuse and powered up again revealed the 5AR4 was arcing over . Is this just a bad tube ??? 280vac??
Macshaft:)
Re: Rectifier Arc, Bad tube?? help
It is very possible to get a bad rectifier right out of the box and that is the way it usually manifests itself. I have had really bad luck with Sovtek 5ar4s. I tried 2 brand new ones in my Rocket build (I only owned two). One lasted about an hour and the other started arcing as soon as I installed it and flipped the standby switch. I threw in a NOS GE and it has worked great ever since. I now buy JJs
Wow, I pretty much use nothing but Sovtek 5AR4 and some GT with no problems but like you said Dana it can happen.
got 2 "NEW" valve arts gz34s bad out of the box for a 36 watter. looked like chinese 5ar4s.. I have better luck using the JJ myself for the current made tubes..but the NOS ones are really the best.
Bad 5AR4
Hey thanks guys
, I`ll try the one out of my first Rocket(Ellen Rachel) . That one is a JJ as well . Both bought from a local guy , maybe he`ll give me another one . Did not think a wiring issue would do that , and the PT voltages measured were within a few volts of the other Rocket . I think a 5AR4 is good for 550vac a side?? .
Thanx again , gotta fire up before the kids go to bed
Cam![Very Happy :D](./images/smilies/icon_biggrin.gif)
Cam
Macshaft:)
Maybe some thing else
![Question :?:](./images/smilies/icon_question.gif)
Macshaft:)
Since it fires up with no tubes installed then you might want to try a different set of tubes. 20 seconds is about the time it takes for output tubes to come up to temp and start drawing current. Sounds like something is shorting out.
Posted: Tue Apr 07, 2009 10:01 am Post subject:
I have not fliped the standby yet , so the only thing powered up is the first P.S. cap(80uF) . gotta be the cap , socket termination is good , no loose strands . I don`t have a meter that will measure this large cap . Maybe I will try a different cap . I have some 68uF`s i can try .Warm up time would apply to the 5AR4 as well I guess??![Shocked :shock:](./images/smilies/icon_eek.gif)
Macshaft:)
Technically, an 80uf cap is too big for a 5AR4 to see right out of the gate. Usually, this sort of thing is not a problem, but you never know - I'd try a 40uf cap, or smaller, just for troubleshooting purposes.
Plus one, the 5AR4 has a max first filter value of 60uf.
That may or may not cause issues since you are only over spec a bit.
But it will be harder on the tube.
5AR4 arcing
Did not get enough time to check unloaded DC voltage on the first cap .
A.C. to the 5Ar4 is 560vac or 280vac a side . Maybe I am over the Mallory spec of 450vdc.?? and the cap is shorting ??![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Macshaft:)
I think you should be alright with a 450 volt cap with those kinds of voltages.
The size of that cap might be the issue. It'll make a current spike that exceeds
the peak rating on the rectifier plate. Ive seen plenty of shorts, and they
dont usually take out the rectifier.
lazymaryamps
My Bad Rectifier dummy
![Embarassed :oops:](./images/smilies/icon_redface.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Macshaft:)
