Classic Tone Vox AC30 transformer set
Doxie man
Post by Doxie man »
Can any of you guys attest to using the complete set from Classic Tone ? PT/OT/choke ?
How does it sound in a Rocket build ? The last build I did I used their Wreck PT & OT. I used the 300V HT tap on the PT. The Wreck OT is a 6.6k primary ( better suited for an Ecpress I know) Im itching to do another Rocket and am considering their VOX set as it will be closer to true Rocket specs (280-0-280 HT) on that PT and a 4K primary on the OT. I was curious how others liked the overall tone using that set.
Roe
Re: Classic Tone Vox AC30 transformer set
Post by Roe »
THe OT is excellent. Sounds warm and rich with firm bass. Not too bright
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
RJ Guitars
Post by RJ Guitars »
They are not bad for the price, but I definitely prefer Heyboer for my Roads packages.
http://www.rjguitars.net
Post by Mark »
You wouldn't use an AC-30 set, you would use the Trainwreck power transformer and the A470 output transformer for the Rocket. When did 280-0-280 HT become true Rocket specs? I believe or 250-0-250 vac or 260-0-260 vac is the real secondary voltage. I have used a Classictone Trainwreck power transformer with a 260-0-260 vac secondary voltage and I have a rail voltage of 315VDC which is higher than the required 300VDC.
With 300VDC the output valves are running at 100% plate dissipation. This where you want the amp, higher rail voltages mean reduced output valve life and brighter tone. Timbre is subjective but I don't think the Rocket needs to be brighter. As far as adjusting the cathode resistor to suit, I've the changes need to be drastic to have a real effect. The difference between a 50 ohm and a 62 ohm resistor is really quite subtle.
Post by Mark »
Interesting RJ why do you prefer the Heyboer transformers?
I have played amps with Classictone transformers and they sound fine. Is there something that I'm missing?
