Baddog01 wrote:Chip, Sounds interesting.
Does a dunble ator affect the tone of the amp without effects running through it?
Keith
Indeed, it can act as an extra tone control and master volume. I don't have a master volume bright cap on my 102 and so I use the bright switches on the Dumbleator instead, it gives extra control over the brightness of the amp IMHO this way.
Structo wrote:There have been discussions about phasing on the output of Dumbles.
Sure,i`m SIMPLY adding in here, this guy i`m sure hasn`t seen it, if you`d like just grab the link, n lettem see it, these guys were on speakers, was i OFF topic?? If so, have moderator remove it pls!
When it comes to my post I'm open to any input. If the subject changes to speakers or cabs on ok with it. Anything that can help me learn more about this rig the better.
I did check out the phase inverter thing again and it doesn't look to bad. I do t have a signal generator or dummy load so I'm going to have to try the meter method. Sound alike allot of it is ear anyways. Close your eyes and let the music flow. If it sounds right you will know.
One speaker works fine but the other has a buzz to it. I removed the dust cap and it looks like the cap wasn't put on correctly. If I push the cone in and out a bit it didn't make noise but if I tapped on the dust cap I got a crackling noise. I also had a wide noise when I tapped on the speaker magnet. I ordered some new dust caps and glue. I'm going to do more testing of the speaker and if it seems ok I'll intall a new dust cap.
One of the speakers is bad so I'm going to order a replacement cone for it at some point. Just ordered a tl-806 cab off of ebay-:) need to order a new output transformer so I can run an 8ohm load. The cab is going to be a raw cab with no hardware or covering. Might stain it but not sure yet. The EV should love it's new home when it gets here:)
Hey Keith-
Just an FYI, Alexander, and many others, have run 1X12 TL806 cabs with single EVM12l with
a standard, that is 4 ohm, output transformer.
Don't spend the money unless you don't like how it sounds.
It's a tried and true application.
I still really want the option of running 4 ohm and 8 ohm cabinets. I'm selling stuff that I don't use anymore so it's really not wasted money. I have another amp I could use either transformer in.
