Coax (shielded) cable
pula58
Post by pula58 »
I have a batch of RG 187...the inner conductor is SO thin...makes me worried about long term reliability.
What are you folks using for Coax that has a reasonably low capacitance per foot, but also has an inner conductor that is robust.
I had some RG 187 from Apex Jr..loved it..
Then I got another batch...and on this batch the inner conductor seems extremely thin/frail.
M
You should not need anything more than 22 ga to use within a amp and with the currents involved .
pula58
Re: Coax (shielded) cable
Post by pula58 »
the inner conductor of this coax is way thinner than 22 AWG. I am concerned about reliability in terms of mechanical reliability, not current limits.
Phil_S
Post by Phil_S »
What I'm finding says it's good for 1200V. http://www7.taosnet.com/ebear/coaxlist.html The wire size of the inner conductor is listed as .012" http://www.timesmicrowave.com/products/ ... ads/54.pdf which is roughly the size of 28AWG. 22AWG is .0254" diameter.
In general, I dislike working with the inner conductor on coax because it doesn't hold a twist and is difficult to solder. It just doesn't play nice. Am I using the wrong stuff?
I like RG-316. The PTFE insulation make it very easy to work with. Approx 1/8" diameter. Silver plated braid and center conductor. Very easy to solder and you will not melt any insulation.
[img:1024:768]http://sluckeyamps.com/VAC15/14.jpg[/img]
labb
Post by labb »
I use RG-174. Never had any problems with it.
pula58
Post by pula58 »
davent
Post by davent »
Secure the cable to the chassis so it can't flop about and there should be no strain on the soldered joints.
And... PTFE coax like pictured, is a joy to work with, i've some Teflon/Kapton that's terrific.Very small outer diameter, maybe 26awg inner conductor. Been using for years, never an issue.
dave
ApexJr.
Post by ApexJr. »
pula58 wrote:I have a batch of RG 187...the inner conductor is SO thin...makes me worried about long term reliability.
I find that odd
The RG 187 A/U is mil spec and should be pretty close to the same.
I do stock other numbers and also 24 and 20 Awg single conductor
Shielded too.
andresound
Post by andresound »
I have used this cable as well. This a great sounding cable. The center conductor IS thin!! :shock: However, I cable tie and secure cable on something. There is a 75 ohm version (RG179) and it is thicker.
UsableThought
Post by UsableThought »
What is wanted for wiring an amp is not called coax, but "shielded hookup wire." When I think of coax, it's for things like carrying an FM or cable TV signal for relatively long distances, vs. the short distances required in an amp chassis - for coax the inner insulation is typically a heavy plastic one-piece surround; and there are probably other differences as well. See Wikipedia:
Coaxial cable differs from other shielded cable used for carrying lower-frequency signals, in that the dimensions of the cable are controlled to give a precise, constant conductor spacing, which is needed for it to function efficiently as a transmission line.
Anyway, seems a simple problem to solve - if you're not happy w/ the wire you're using, buy some that you know will be satisfactory. I had some braided shield wire I had used for a wiring harness in a guitar - okay stuff except the braid was naked, so I was having to add heatshrink, very laborious. So I went to Digikey - like Mouser they make it easy to filter for whatever you want, e.g. PTFE insulation, etc:
Product Index > Cables, Wires > Single Conductor Cables (Hook-Up Wire)
I ended up choosing a very nice & quite inexpensive PVC-jacketed 22AWG shielded wire - and MUCH better prices than you can get at TubeDepot or Small Bear or wherever:
https://www.digikey.com/product-search/ ... 2030-00342
FourT6and2
Post by FourT6and2 »
I've had good results with RG-188/U. The white Teflon stuff from Belden.
joesatch
Post by joesatch »
I am on the hunt for this cable. Only can find it on Amazon for $240. Anyone know where i can buy Belden RG-188A/U ? I might connect the shield to my V1 plate so it needs to be serious cable to be safe over 1000v rating.
joesatch
Post by joesatch »
i saw that. It's not Belden at least it doesn't appear to be. Can it withstand 1000v?
