'63 Blonde Bassman 6G6B
Re: '63 Blonde Bassman 6G6B
What a beauty...
Sure it sounds awesome and thanks for the tips!
That looks awesome, where did you get the chassis and faceplate from. They are impossible to get now. I got one from TAD years ago for the Bassman 100 I rebuilt this year.
Thanks you, ChopSauce, that is very kind.
Thanks a lot, Mark. I actually got the chassis from Mark Fowler, but I believe he might have gotten it either from Mike Marsh/Marsh Amplification or this guy on Ebay that sells replica Fender chassis. I think he goes by Zachmdhunter or something like that. Perhaps Mark will chime in. I should mention that I had the chassis and cap pan bead blasted and coated at a local coatings shop to remove the tooling marks and make it extra nice and not rust.
2 others liked this
So happy to see this amp come together. You've done a great job as expected, it looks absolutely fantastic.
Glad you like the bass channel after all of my carry on. Sounds like the sweep and performance of Martin's tapped treble pot replacement circuit is better than the weird taper of the new versions.
What speakers and cab config are you running it through?
I’ve written to Mike Marsh and never gotten a reply. I’ll try the other guy. As far as speakers go, the Celestion Vintage 30’s have been popular as Brian Setzer uses them. The Bassman cab has been criticised for being too small for the 2 X 12” speakers. I have one loaded with Kendrick speakers and I can’t complain, though I don’t know any differently.
It's a real beauty, Dave, nicely done!
Here's a very authentic-looking option: http://www.solandfa.com/products-Bassma ... is-Kit.asp
Thanks a lot, Martin! The treble pot works nicely.
Such a good job Dave, love your amp.
The chassis/plates I got from Mike Marsh and other chassis and cap cans I got from ebay Zachmdhunder.
- norburybrook
Wow!! Dave that just looks amazing. Really beautiful build.
M
M
- Colossal
Thanks Marcus!
Nice build! I've come to like the brownface and the way it fills the sweet spot between the tweed and blackface sound more and more lately.
Although it's a dumble mod (I'm not a fan of the dumble overdrive), the PI balance pot intrigues me quite a lot.
You don't happen to have any sound clips of before/after adjusting the balance, or even better WHILE you adjust it?
I once installed a 25k pot between the (4k7) tail and cathode resistor to hear if different tail voltages (and thus PI balance) sounded any different. To a certain degree it does the same job as the balance pot to level out the plate voltages. However, to me anyway, the different tail voltages didn't make any audible differences, but I may have turned the pot too fast to note any possible sweet spots as the sweet spot apparently is in a very small range.
No, I'm sorry, I don't have any clips. I kind of doubt it would be audible. You can hear the effect when you are standing in front of the amp and turning the trimmer. The sound gets a little thicker and wider. For what it's worth, I maxed out the trimmer to +6VDC to the inverting side.Bergheim wrote: ↑Tue Oct 06, 2020 4:45 pm Nice build! I've come to like the brownface and the way it fills the sweet spot between the tweed and blackface sound more and more lately.
Okay, thanks. It may be the same thing I think I noticed when adjusting the tail voltage.Colossal wrote: ↑Tue Oct 06, 2020 5:03 pm No, I'm sorry, I don't have any clips. I kind of doubt it would be audible. You can hear the effect when you are standing in front of the amp and turning the trimmer. The sound gets a little thicker and wider. For what it's worth, I maxed out the trimmer to +6VDC to the inverting side.
