Liverpool Chassis Layout
johno9
Post by johno9 »
Is there a layout for the top of the chassis (transformer locations) for the Liverpool? I'm using Pacific Audio transformers.
Thanks.
Re: Liverpool Chassis Layout
Not really needed... You can see the socket positions from the underside, and the transformers are mounted in the same way as for the Express. They are on the same centerline front-to-back on the power end of the chassis, with their cores 90-degrees apart. Use the lead wire grommets on the drawing as a guide, but be sure to position them so that the chassis will slide into the head cab without the transformers hitting anything.
johno9
Post by johno9 »
Thanks Martin. I didn't think to look at the Express files.
