Littlewyan wrote: ↑Tue Feb 07, 2023 9:07 am
How about this clip? Does your Liverpool sound similar to this? (Bear in mind I think he might be using a G12H cab here)
Sounded good. It is different to other clips though I see what you mean. Unfortunately I've never heard an actual Liverpool in person so I can only go off of clips! I've got an Express clone myself.
What settings and guitar did you use?
Guitar is a Suhr Pete Thorn Signature. Amp settings were volume noon, treble and mid 2:00, bass 10:00, presence noon. 100pF bright cap. At one point I switch the the 500pF bright cap.
Check out my band: https://www.facebook.com/ungluedband
Littlewyan wrote: ↑Wed Feb 08, 2023 3:25 pm
What values did you use for the tonestack? Have you checked your wiring? Do the controls all work how they should? Same for the presence.
47pF treble, 22nF mid and bass. 100nF presence. Yep, they all seem to work as they should.
I think the Bass pot is meant to be a Linear taper 250K. I'm a bit concerned that there could be something else wrong here, as with a 250K Log Taper bass pot and an already big low end cut with 2.2nF and 68K you should have a very lean amp right now. I actually thought it sounded a tad trebley in the clip you posted, maybe because so much bass is being cut. What cab do you normally play through?
Littlewyan wrote: ↑Wed Feb 08, 2023 9:36 pm
2 different cabs. A Suhr 212 closed back with Greenbacks. And another 212 semi open back with a V30/G12H-30 combination.
What if you clip another 2.2nF in parallel with the existing 2.2nF between the 2nd and 3rd stages? Interested to see if you get closer to Pete's sound or if you feel the bass situation becomes much worse.
