C-lator hum
Re: C-lator hum
Perhaps the PT is leaking a lot of magnetic flux, and the enclosure is creating a path for induced current to flow when the cover is on? Did you try powering the C-lator with only the PT primary connected, in the same configuration that we have been discussing (only C-lator output cable plugged into the amp)? I'm starting to think the problem is the transformer itself.
Re: C-lator hum
No I haven't come to that yet. But will try tomorrow.martin manning wrote: ↑Tue Mar 19, 2024 7:43 pm Perhaps the PT is leaking a lot of magnetic flux, and the enclosure is creating a path for induced current to flow? Did you try powering the C-lator with only the PT primary connected, in the same configuration that we have been discussing (only C-lator output cable plugged into the amp)? I'm starting to think the problem is the transformer itself.
Maybe there's dual problems: PT leaking magnetic flux, and something weird about grounding? But yes, I still suspect the PT. Their previously layout had the PT outside the chassis, and have not heard of problems with those.
Re: C-lator hum
There is no reason that the PT can't be inside the chassis, recall mine and others have been built that way with no issues.
How much height do you have inside the chassis? Let's see if there is a replacement PT that would fit.
Re: C-lator hum
40 mm height inside the chassis. The PT has 41 mm height though, so it should actually bend the lid.martin manning wrote: ↑Tue Mar 19, 2024 7:57 pm There is no reason that the PT can't be inside the chassis, recall mine and others have been built that way with no issues.
If this PT design has excessive magnetic flux that is converted to current inside a closed chassis, maybe that was not a problem before when this PT design was mounted outside?
I could disconnect the secondaries. Then extend the leads, put the PT outside the chassis, lift the ground and see what happens in each step.
Re: C-lator hum
aha mechanical vibratios also are causing humm.. i forget that before but also can be in your case! mechanical vibrations are shaking sensitive grids of input tube and making small voltage, like microphone, and you have permanent hum inserted via signal with vibrating!ynor wrote: ↑Tue Mar 19, 2024 7:03 pm And another mystery:
While not connected to anything, the PT of the C-lator vibrates and hums when the lid is on. I can feel the vibrations when touching the chassis. But when I remove the top lid, the PT is completely quiet, as in no vibrations. Why is that?? Putting the lid on makes everything worse: the vibrations appear, and the hum is increased in the amp.
ok remove power transformer out from the chassis with long wires to cure that and probably if is gone, you cannot use this PT anymore.. there is a solution but after we will see.
Re: C-lator hum
Yes, I'm waiting for my new meter (with oscilloscope) to arrive
Re: C-lator hum
5.6 VAC for the heater is too low this is starving filament, and is not good for the tube.. this PT has several primary taps? need to change tap...
Re: C-lator hum
Weird thing is, when lid is off it does not vibrate at all. Put the lid on, and the whole chassis starts to vibrate and also sounds like an electrical buzz, from the chassis and PT without connection to the amp.bepone wrote: ↑Tue Mar 19, 2024 8:52 pm aha mechanical vibratios also are causing humm.. i forget that before but also can be in your case! mechanical vibrations are shaking sensitive grids of input tube and making small voltage, like microphone, and you have permanent hum inserted via signal with vibrating!
Re: C-lator hum
What are the chassis and lid made of? Are they both the same material?
Glenn
I solder better than I play.
Re: C-lator hum
The chassis and lid are made of steel. This could explain vibrations. Especially when it lays lose on top of the chassis.
The transformer in the enclosure was probably not the best idea Nik had. I dont understand it either because it looks like the exact same PT, except the bell cover.
Re: C-lator hum
Can I just check: Are you saying here that having the device main power switch set to off (I.e. primary PT loop is broken) you *still* get a hum, albeit lesser, that only stops when the IEC cord is removed?
Can you please retest that, ensuring that the caps are discharged?
