I've got hold of a bunch of NOS CV1052s otherwise known as EL32s
They appear to be from 1969 and from Mullard Blackburn UK
Are they any use? what could I build with them?
Craig
CV1052 - EL32
CV1052 - EL32
Thinking about my second build.
Re: CV1052 - EL32
https://frank.pocnet.net/sheets/154/e/EL32.pdf
Audio output tube, kinda like a low-power pentode 6V6, actually pretty close to a 6K6.
Re: CV1052 - EL32
Not too far off from a 6AQ5, but man that low .200 amp of heater current need is hard to come by!
Re: CV1052 - EL32
Thanks for the replies,
I'll give it some thought, I hadn't even noticed the top connection until now, that might complicate matters.
Craig
Craig
Re: CV1052 - EL32
Interesting grid connection. Those leads would be screaming for pasties!
Just plug it in, man.
