Princeton Reverb Gerber Files
I recently made a Princeton Reverb with couple minor tweaks. Here are the gerber files for the pcb if anyone wants to use them. http://ghr.fi/guitaramps/trinceton/prin ... 50x110.zip
Schematic and layout attached
Here is a sound sample we recorded:
Re: Princeton Reverb Gerber Files
Beautiful work and great sounding amp!
How do the preamp tubes plug into your board? Is there a special socket .
Congrats!
Cheers
Guy
Congrats!
Cheers
Guy
Noval PCB socket
Thank you Heikki!
Cheers
G
Cheers
G
quick question
What is R39 for and what do you have in there?
I cant tell from the pics
Steve
Steve
I can't see the value written anywhere, so yeah what 'is' R39, it's a dropper resistor that takes the place of the choke on some builds, basically taking the input voltage post rectification down a notch before the first filter cap.
Great project I finished my build over the weekend amp works great and is dead quiet
I used r39 for my standby switch I also did not have those fuse holders so jumped over them
really cool project I used a really big chassis 17x10x2 but I had lots of room to mount the board and
not have to cross mount any transformers thanks again for the gerbers
R39 is optional "sag" resistor. You can put put 50 - 100 ohm 10W resistor there or if you don't want to use it just put a jumper over it or put stand by switch there like you did. I used NTC thermistor there as R39 to limit inrush current so I don't blow my B+ fuses at start up.
Thanks for posting this, Heikki.
Do you recall what your B+ was coming out of your rectifier diodes/at R39?
Just plug it in, man.
As I recall in my amp B+ is about 390V. For anyone building this what your B+ voltage is going to be is going to depend on the power transformer you use, but B+ anywhere between 350V - 420V should be fine. If it's in that range there shouldn't be huge impact on tone.
Thank you, Heikki. That's what I'm shooting for, but I'm about 50 volts too low at the moment. Working it out...
since there's so many iterations of the Princeton, which exact model is this made after?
and is there a way to add a master volume to the circuit so I don't have to evacuate the house if I want some chrunchy to overdriven sounds.
and lastly, what transformer did you use for your build?
- erwin_ve
There is a schematic and layout in the opening post.VolkerStaub wrote: ↑Tue Mar 14, 2023 11:00 am since there's so many iterations of the Princeton, which exact model is this made after?
The original poster was last active in 2021, it may take a while to get a response.
Best,
Erwin
