ODS Inspired Build; #102 Values with Buffered FX Loop
Re: ODS Inspired Build; #102 Values with Buffered FX Loop
Great looking build Glenn
The OT phase test info would be a good addition for the FAQ section too
Thank you Raoul. It's been a challenge for sure, but one I've enjoyed. I've enjoyed watching your builds, please keep posting them.Raoul Duke wrote: ↑Fri Apr 05, 2024 11:36 am Very interesting build Glenn! Impressive figuring it all out like you did. Way above my cranium, lol.
Thank you Tim.
I haven't spent any time with this lately but hope to this weekend. I need to post some voltages and get some opinions about them.
Glenn
I solder better than I play.
Voltages:
B+ 450; B+2 448
PTs: 33.5/37.8 & 32.3/37.7mA
~17 watts/56%
Sovtek 6L6WXT+
B+3 430
PI 286/29
B+3a 387
FX2 251
B+3b 383
FX1 383/103 (Cathode Follower)
B+4 317
OD1 192
OD2 201
B+5 310
CL1 190
CL2 193
Heaters 7.0vac (a bit high)
Input 123 vac
B+ 450; B+2 448
~17 watts/56%
Sovtek 6L6WXT+
B+3 430
PI 286/29
B+3a 387
FX2 251
B+3b 383
B+4 317
OD1 192
OD2 201
B+5 310
CL1 190
CL2 193
Input 123 vac
Glenn
I put in some JJ KT66 power tubes I have to see what it would do for the heater voltage. They brought it down to 6.9vac. They sound great in this amp. Good highs. Brite. I see how they could cause the Ice Pick effect but luckily it's not bad in this amp and can be dialed down. The lows are nice and solid. Mids are good. I can see why these would be suitable for HiFi use.
FX loop has 60hz on it. Could just be the tube but first I need to address the CF plate voltage. It's at 383vdc while Martin's values I used have it at 260. I put in the wrong power filter dropping resistor, 2k2 installed should be 100k. The plate voltage on the other tube needs to come down a bit too, it's currently at 251. I'm going to change this before powering it up again.
Glenn
For the built-in D'lator I believe the best plan is making the D'lator signal grounds at the loop jacks. Do you have a branch off the screen filter for the loop power? That should be pretty clean; the negative leads of the extra filters can be grounded with the screen filter.
Grounding as follows:
B+1 ground to chassis near rectifier/bias board with HV center tap, and rectifier/bias.
B+2 & 2b to chassis near power tubes.
B+ 3, 3a, 3b, 4 and 5 (on filter board these are all tied together) to chassis near input jack with CL, OD, FX and PI grounds. Input and FX jacks isolated and grounded with these too. FET also grounded here.
I'm certain the hum in the FX is the tube. CL had the hum, swapping CL and FX the hum followed the tube. It isn't horrible but definitely there. I'm sure the voltages aren't helping, cathode on CF is about 100vdc.
The FX power comes off B+3, PI filter section. Currently B+3>22k>B+3a>2k2>B+3b. I need to increase the 22k a bit and 2k2 a bunch. I'll got some values from 22k to 33k to try, then 2k2 up *to 100k* for the other one. Sound like a good plan?
*edit*
*edit*
Glenn
Quick update.
Changed power supply resistors to Dumbleator tube and voltages fell into line. This helped the hum but changing the tube out helped a bunch more. Turns out I had a large plate in it, a lower gain tube really helped. I think putting it in a cabinet will help a lot more.
The Dumbleator is working well. Like a different OD section if used by itself, so far I haven't actually plugged any pedals into it. Bypass works well, in bypass it's like it isn't there-as it should be.
I'm considering the idea of making the Dumbleator footswitchable. I'd have to free up a switch, probably put the PAB and OD on the same switch? PAB, OD & FET are what I have on the footswitch now.
I've been sidetracked so haven't spent much time on it lately. Too many danged squirrels running around...
Glenn
Been doing some work with this amp today. A while back I robbed the PT from it to replace the one in my SSS. I just received and installed the replacement from Amp Parts Direct. A Heyboer for a Fender 100Watt, but with 320-0-320 vs the 340-0-340 Heyboer from Mojotone that I removed. New voltages:
102 w/Dumbleator Voltages
B+: 414: 36mA bias
B+2: 413
B+3a: 363; 240
B+3b: 262
B+4 (PI): 400; 268; 276
B+5 (V2): 294; 183; 180
B+6 (V1): 285; 178; 178
The B+ and B+2 are down over 30 volts.
B+3a/b are just where I want them.
B+4 PI should be 280/290
V2 should be 205/205
V1 should be 200/200
Power dropping resistors are:
B+2 > 2k2 > B+4 > 22k > B+5 > 2k2 > B+6
Jumpering across the 2k2 between B+2/4 gives 280/285 close enough to what 102 has (and highest I can get). I understand this combines the two power stages and puts the filtering caps in parallel. Is this going to cause any adverse affects? Any reason not to replace this 2k2 with a wire?
With this jumper in place it outs V2 at 187/189 and V1 at 184/184. Adjusting the 22k will bring these voltages to where they should be. I have 18k and 20k on hand, is it better for these voltages to be a bit higher or lower than specified on these tubes?
B+: 414: 36mA bias
B+2: 413
B+3a: 363; 240
B+3b: 262
Glenn
If you do that you lose the decoupling of the power nodes. I'd keep it to a minimum of 1k.GAStan wrote: ↑Wed May 29, 2024 8:34 pm Jumpering across the 2k2 between B+2/4 gives 280/285 close enough to what 102 has (and highest I can get). I understand this combines the two power stages and puts the filtering caps in parallel. Is this going to cause any adverse affects? Any reason not to replace this 2k2 with a wire?
Adjusting the 22k is the right move. You might want to try paralleling some larger resistor across it to see how you like it vs. the lower voltage.
Hey Glenn, I have that same PT in my #102 and my B+ hangs around 420-425 volts depending on line voltage. But the rest of voltages were about right with the standard dropping string. Maybe moving preamp tubes around will help.
-Dan
-Dan
