Mustard capacitors sets and spares
FranciscoPerez
Hi everyone.
Given the big success of my previous thread about piher sets, I decided I could part with some mustards you guys seem to be using in your replicas and restorations. Those are 90% labelled bianchi, some philips are available too.
Do not hesitate to message me if interested.
Prices depend on value and availability, but as with pihers, I will keep them as reasonable as possible.
For instance, 2k2 400v caps are 3,5 eur each.
Shipping worldwide from Spain is very reasonable, tracked. I'm shipping to USA, Australia, Japan... all the time, at around 8 eur. Same with Europe.
All typical values available!!
Plenty of 22k, 10k, 2k2 @ 400v etc
Thank you!!
Thank you!!
FranciscoPerez
Re: Mustard capacitors sets and spares
I'm running out of 22k 400v, but still plenty of other values. I also hace 680k 160v chiclet capacitors for your ecc83 cathodes!!
FranciscoPerez
I'm back from vacation, and all values still available!
FranciscoPerez
Happy new year! All values still available.
I purchased a set of mustard and piers from Francisco about 1-2 months ago. The 22K's are fine but the .1uf cap leads are too short to reach the turrets on a standard Marshall board. Just a heads up for anyone interested.
I found no need to reach out to Francisco since it obvious knew this when picking them. Perhaps this is expected in the industry but personally I expected caps that I can use in the amp I was building without having to solder additional wire to the leads. Just make sure you ask before buying.
FranciscoPerez
Hi!! So sorry about that, I did not see your post here until today. I can offer a full refund or pick some for you that have longer leads, thought they would fit fine, my apologies. If you did not use them yet please pm me and we will work thing out.
I’m afraid I just check my PM regularly but did not checked this thread.
Fran
Fran
FranciscoPerez
Most values still available!!
I issued a full refund to lgehrig4, since I mistakenly thought we had discussed about the shorter leads for this specific capacitor value, and it was not the case.
Fran
Fran
FranciscoPerez
Email sent! Thank you!
- chief mushroom cloud
