I´m from Germany,and build the #002 SSS from Scratch,taking R.Colgan´s Layout and a few Schematics from Net.
I drilled a Blanko Marshall Style Chassis,only 10mm smaller by my self,go with selfmade Eyelet Boards and laser engraved Faceplates.
Some Mod´s I integrated: Standby Switch direct after Rectifier,but than another Rectifier Diode in Series after the Switch,and Stby Switch referenced to gnd via 1MΩ,a parallel 47K Resistor,let some current flow in Standby Mode,for safer Operating.
Also i integrated a Switch-on Current Limiter with NTC and Relay,witch bridge the NTC with a Delay of 5 sec´s between Power-Sw. and PT.
furthermore,i go with mannings Bipolar Bias Supply and Filter Mod.
After a few Prob´s. the Amp is now full working and Great Sounding,only the Headshell i have still to build.Here is the Buildprocess, in a German Forum: https://www.musikding.rocks/forum/index ... ng-singer/ ,you can there also take a look on my other Builds,like a Dumble ODS,Marshall JTM45,Hiwatt Dr103,Orange OR120 as 50W Version,6G15 standalone Reverb,etc...
best regards from Germany,
Micha
Here some Pics:
