Steel String Singer#002 build from Scratch
Hendrixianer
Post by Hendrixianer »
Hi Folks :D
I´m from Germany,and build the #002 SSS from Scratch,taking R.Colgan´s Layout and a few Schematics from Net.
I drilled a Blanko Marshall Style Chassis,only 10mm smaller by my self,go with selfmade Eyelet Boards and laser engraved Faceplates.
Some Mod´s I integrated: Standby Switch direct after Rectifier,but than another Rectifier Diode in Series after the Switch,and Stby Switch referenced to gnd via 1MΩ,a parallel 47K Resistor,let some current flow in Standby Mode,for safer Operating.
Also i integrated a Switch-on Current Limiter with NTC and Relay,witch bridge the NTC with a Delay of 5 sec´s between Power-Sw. and PT.
furthermore,i go with mannings Bipolar Bias Supply and Filter Mod.
After a few Prob´s. the Amp is now full working and Great Sounding,only the Headshell i have still to build.Here is the Buildprocess, in a German Forum: https://www.musikding.rocks/forum/index ... ng-singer/ ,you can there also take a look on my other Builds,like a Dumble ODS,Marshall JTM45,Hiwatt Dr103,Orange OR120 as 50W Version,6G15 standalone Reverb,etc...
best regards from Germany,
Micha
Here some Pics:
Last edited by Hendrixianer on Mon Dec 16, 2024 11:10 pm, edited 4 times in total.
DIY Amps: Marshall JTM45,Orange Grafik II 50W,Some 18W Marshalls,Dumble ODS 50W,Hiwatt DR103,Madamp G3 Blues,Dumble Steel String Singer, Fender Standalone Reverb 6G15,a few Hundred Pedals,like Uni-Vibe,etc,etc... :D
erwin_ve
Re: Steel String Singer#002 build from Scratch
Post by erwin_ve »
Great build Micha! You put a lot of effort in to make this from scratch.
Nice to see some little twist compared to the original, the true marks of someone who knows what he's doing.
Congrats!
Erwin
Hendrixianer
Hi Erwin,thanks,
This build coast me Blood Sweat and Tears :wink: ,but I´m very Proud,to get it full working and great Sounding by my self :D
Hendrixianer
Just forgot,Here´s a Protocol of Measurements I´ve taken:
Hendrixianer
Another Mod:
Heater Elevation to +53VDC using a Voltage Divider 330K:68K after Rectifier,now i´have only a Voltage potential difference on cathode followers (Heater to Cathode)V2,V3 about 170V instead of 220Vbefore elevating it !
Vfk limiting Value of a 7025/12ax7 is 180V for Tubes from Current Production.
It seems,Nobody take care of it,in all the Steel String Singer clones :roll:
dbharris
Post by dbharris »
Great looking build!
Hendrixianer
Mods:
Hendrixianer
thanks, @dbharris :oops:
dbharris
Post by dbharris »
Is that a wah inductor you used?
-Dan
Hendrixianer
No,its the Inductor,Mesa and two Rock uses....
But, I think,it´s more Snakeoil in the SSS,and has no Effekt to the Sound.I will try one Day,test it switchable for A/B Compare......
https://www.tubeampdoctor.com/drosselsp ... en-eq-0-39
timrobertson100
Post by timrobertson100 »
Beautiful build.
Hendrixianer
Corrected Filter Switches to work Clockwise :lol:
Hendrixianer
timrobertson100 wrote: Sun Dec 15, 2024 9:04 pm Beautiful build.
Thank´s :)
dbharris
Post by dbharris »
Hendrixianer wrote: Sun Dec 15, 2024 5:39 pm No,its the Inductor,Mesa and two Rock uses....
Thanks, I snagged one of the triad inductors from another member here a while back for whenever I get around to this build. I'm in the camp that you may as well build it as close to the original just in case. Though it seems possible HAD was maybe just having a laugh by including some of these things like the coiled wire and inductors.
Would love to hear clips once you are satisfied with it.
-Dan
Hendrixianer
dbharris wrote: Mon Dec 16, 2024 11:29 pm
-Dan
Yes,thats my Intention,and the Induktor,is so cheap,that i give it a try :lol: ,Hovever,not testet until yet,if it makes a difference without it,but i don´t think so :lol: .
Yes,if i had a little more Time and a better recording solution as my damned Smartfon,i will upload some Soundfiles,but i was a Dinosaur,when it comes to recordings,this is not my World,and My Soldering is much better as my Guitar Playing too :lol:
