SO, I got some 1W metal-film R's...and
VacuumVoodoo
Re: SO, I got some 1W metal-film R's...and
Post by VacuumVoodoo »
Structo wrote: Check out the CCF60 series from Vishay.
They are nice!
500v, 1% tolerance
http://www.mouser.com/Passive-Component ... 60&FS=True
Yes. they look nice. Now take a hammer a smash the epoxy coating to expose the resistor proper. Surprise :!: :lol:
Aleksander Niemand
Life's a party but you get invited only once...
affiliation:TUBEWONDER AMPS
Zagray!-review
Looks like Tube Depot has misquoted the working voltage spec- it's 300, not 500. The often-used RN65's are rated at 350, FWIW.
Aleks, I must admit I've never taken a hammer to a resistor. What is under the coating?
Yes, do tell.
VacuumVoodoo
C'mon guys, I'm sure you can afford to sacrifice one resistor to satisfy your curiosity. Take one for the team.
I have no more CCFs at this time... :wink:
Hint: remember that X-mas when you got a present in a big box only to find it was a waste of space?
Aleksander Niemand
Zagray!-review
toner
Post by toner »
ToneMerc wrote:
tele caster wrote:I used some of these cmf60. About the same size as 1/2 watt, but rated at 500v. Has anyone else tried these?
http://tubedepot.com/r-cmf60.html
Yes, although not in high voltage areas like plate feeds.
TM
350v should be plenty, right? so whats the good high voltage resister options to get?
