Is there an ODS layout with an internal loop?
Bob Simpson
Post by Bob Simpson »
I've used the search, and looked through all the layout stickies I can find.
I've got a 4 noval 4 octal chassis, and I'd like to implement a dumbleator loop internal to the chassis.
Is there a layout for this type of amp available?
Thanks in advance.
Bob Simpson
ChrisM
Re: Is there an ODS layout with an internal loop?
Post by ChrisM »
This should help get you started.
http://ampgarage.com/forum/download/file.php?id=15497
(huge layout warning)
Wow!
That drawing is 21" x 11.5"!
Drumslinger
Post by Drumslinger »
Massive! :shock:
butwhatif
Post by butwhatif »
the only issue is that the bias to the input of the (output) stage of the loop will have to be adjusted to accomodate a large clean signal, w/o clipping one side of the waveform, if u have a scope it will make the job easy--
dcribbs1412
Post by dcribbs1412 »
Thanks Chris
will be using this ASAP
butwhatif:
is this an easy adjustment without a scope?
Yes, just use your ears. :D
butwhatif
Post by butwhatif »
it's not that easy to do and get right by ear, there is substantial discussion about this in the forum, it's a matter of picking a resistor pair that creates somewhere betw 25-30vdc as cathode bias for the
output stage. easy to see with a sine wave + a scope ----check this thread
http://ampgarage.com/forum/viewtopic.ph ... ping#52983
I checked mine tonite and i have a 27k tail resistor -and it has +30vdc on the cathode. it passes all signals w/o any uneven clipping
Ok, I get what you are saying.
Yes, I remember when I built my dumbleator, the cathode follower cathode was supposed to be at around 30v.
