OT impedance
jestaudio
OT impedance
Post by jestaudio »
in have a couple of telefunken SE trannies, the secondry is near as dammit 4 ohms the primary around 600 ohms yet from the documentation the primary shoud be 1.2k, does this sound as if the traffo is U/S
Phil_S
Re: OT impedance
Post by Phil_S »
Just how did you determine 600:4 as the impedance ratio?
diagrammatiks
Re: OT impedance
Post by diagrammatiks »
are you sure it's not 8ohm at 1.2k?
jestaudio
Re: OT impedance
Post by jestaudio »
Phil_S wrote:Just how did you determine 600:4 as the impedance ratio?
I was,nt aware i had, i was refering to measurements taken with my DMM in comparison to the information printed on the traffo, the question being if the traffo manufacturer states a impedance of 1.2k and i am reading 600 ohm is the traffo defective
diagrammatiks
Re: OT impedance
you can't measure it like that.
it's just a ratio.
8:600, 16:1200, and 4:300 are functionally the same transformer.
jestaudio
Re: OT impedance
Post by jestaudio »
diagrammatiks wrote:you can't measure it like that.
it's just a ratio.
not to sure i,m following you, correct me if i,m wrong , 4-300 would give 1.2k, is that correct? if so allowing for my DMM not deing my most acurate and slight corrosion i could well be in the ball park
diagrammatiks
Re: OT impedance
sorry you said 4:600 in your original post.
that would be 2:300, 4:600, 8:1200, 16:2400
jestaudio
Re: OT impedance
Post by jestaudio »
diagrammatiks wrote:sorry you said 4:600 in your original post.
Now i am confused :? how do the readings inter-relate to ratios, sorry if i,m being dense :oops:
diagrammatiks
Re: OT impedance
you have to determine the reading on the primary and then the secondary.
that sets up a ratio between the two windings.
if your primary reads 600ohms and your secondary reads 4 ohms then that's a 600:4 ratio.
That means if you hook up a 4 ohm speaker to the secondary the primary will see 600 ohms.
If you hook up an 8ohm speaker to the secondary the primary will see 1200ohms.
Aurora
Re: OT impedance
Post by Aurora »
You cannot use a DVM and measure the DC resistance to determine impedance ratio. DC resistance of teh windings tells nothing about impedance, or rather turns ratio. DC measurements can only briefly tell if the trafo is not shorted or burnt. If there are som specs printed on the trafo, or if you have a spec sheet, you have to rely on them.
Phil_S
Re: OT impedance
Post by Phil_S »
Are you measuring Ohms? That's not how it's done!
You've got to determine the turns ratio based on voltage in/voltage out. Read here: http://www.radioremembered.org/outimp.htm
Use the voltage supplied by a filament winding as your low voltage source.
jestaudio
Re: OT impedance
Post by jestaudio »
diagrammatiks wrote:you have to determine the reading on the primary and then the secondary.
ok so each time i step up a speaker impedance then the primary impedance goes up as well,
yep i think i have it now, just need to find out if i can use this in a 6v6 champ build im looking at
diagrammatiks
Re: OT impedance
Aurora wrote:You cannot use a DVM and measure the DC resistance to determine impedance ratio. DC resistance of teh windings tells nothing about impedance, or rather turns ratio. DC measurements can only briefly tell if the trafo is not shorted or burnt. If there are som specs printed on the trafo, or if you have a spec sheet, you have to rely on them.
yes yes. sorry if that wasn't clear.
make sure you use the right measurements to determine the ratios.
jestaudio
Re: OT impedance
Post by jestaudio »
just rechecked using my works DVM and got 360-4 which would give me about 1400 which is,nt far off the stated 1.2k on the trafo so i would assume if i load it with 8 or 16 ohm speakers that would give me 2.4 or 4.8
Aurora
Re: OT impedance
Post by Aurora »
You still refrain from getiing the point?
