A MUST READ... AGAIN!
talbany
Post by talbany »
I would have to say that out of all the amplifiers out there I have analyzed and documented, Dumble amps without a doubt have been my most studied (with the help of many here) and played..Well over 12 or so years, and have built just about all the various ODS incarnations as well as the SSS, Ultraphonix, Hi-Gain, Hotel Hog, Explosion, Music Man. Occasionally I will go back and re-read this article on Mr Dumble..
The first time I read the article I thought most of it was propaganda, an eccentric touting his amps and designs with not much to offer in terms of building replicas of his amplifiers (Marshmallows and Football fields)..Every time I go back now and read the interview I pickup a little something..I will study his design approach and wiring/building techniques, components and go back and re-read and sure enough, Dumble mentions a little something about it.. I begin to realize he actually thought about, used, and incorporated such things as circuit constants, parts selection, layout lead dress, phase inversion and even the importance of each and every connection (taken individually might not seem important but put them all together).. Also a glimpse into how his amps have evolved over time now makes perfect sense..Although it is a rather broad overview and not at all technical he does mention it and uses all of it in his design and manufacturing processes.. So IMO especially those starting out should look not upon this interview (as I did) as propaganda but a blueprint as to how to build your replicas as well as incorporating these techniques into your own designs..Study and emulate the greats and eventually you will become one!!
I hope this helps!!...Here it is again>>
Your amps have a reputation for almost never breaking down. How do you build in such durability?
Those are absolute guarded secrets. In fact, if you take the amplifier apart, you can't detect how I do it. I definitely have secrets that make the amp perform and last the way it does. With most companies, it's just a misapplication of technology. you don't have to destroy the product--you don't have to get a Variac and turn it up to 170 volts--to get good results. An extreme amount of attention is paid to every connection. Plus, I found which parts last and which ones don't.
What made you gravitate towards electronics in the first place?
I loved music, for one thing. Music's always been a passion. I used to listen to Les Paul and Mary Ford as a kid. Also, I come from an engineering family; my father developed one of the first automatic transmissions. It wasn't hard to absorb the technology; it was just there to do. I also saw that I could make some bucks at it. I started making small pocket radios from scratch for the kids in school for $5.00 a pop. I was doing real well until one day everybody had one, and there were enough radios in the class that you could hear the local rock station at a small din through all the earpieces. So, the teacher finally busted me.
What inspired you to first build an amp?
I was a junior in high school, and this guy named Jack smith came over and wanted me to build a piece of equipment for the junior baseball association. He said that he had access to a "mountain of parts"--I said OK! We went down to this big warehouse, and there were heaps of parts, so we gleaned as many as we could--all free. We built this huge 200-watt power amplifier so they could announce to nine baseball diamonds. As I understand it, it still works today. Then, Jack and I made some Dual showman-type amps, although we couldn't get Fender transformers--they were very tight about what they'd send you--so we used David Hafler transformers, which made the amp sound quite extraordinary.
Prior to building your own amps, had you taken apart others amps such as Fenders and Gibsons?
I can draw some of the those schematics from memory [laughs]. Of course, I had to absorb other approaches. In fact, my old Fender mods I did in the late '60s were exactly the same as the schematics a lot of the later high-gain amplifiers used.
How did you come to make amps for the Ventures?
I was an 18-year-old kid in school in Bakersfield, and I went to see Semie Moseley, who was the only person I had access to there. I walked in and just bold-faced said, "I've got something that sounds like nothing else. You better hear it." And it flipped him out; he said, "This is the best thing I've ever heard." He offered to go in with me to build 10 amplifiers. He bought the parts and paid me $90.00 a week--for about four weeks, and then I had to work for free. But I still got to build 10 amplifiers on a production basis when I was only a kid. They were called Mosrite amps, but they were my design. Actually, I built 11, so I still have the original one I built. The Ventures played through them and were really interested, but it was a little too much rock for them. They wanted me to go into business with them, but I decided against it, and went back to playing in studios and in rock bands.
Did your early amps have certain qualities lacking in commercially available amps of that period?
Yes, I definitely made sure they had more frequency bandwidth. One thing I noticed about the early guitar amps was that they were real limited, especially in the lower end. But you have to be careful to make sure you still keep the proper midrange and treble response. I found that out early on. You can't build a hi-fi circuit and expect it to be a good guitar amp--it just doesn't work out. you need a whole different response curve. But I did notice that if I put a little more low-end into the preamp circuitry, it was much more tasteful and fun to play.
Once you got started, did a Dumble philosophy evolve?
I try to be flexible. I've always been aware that whatever I make has to be crafted with the best intentions. Never have anything shoddy. Always makes sure that it works and looks perfect. The actual techniques I use to get the sound that I go after have evolved extensively. It's a growing process. That's the toughest thing about staying with one thing. you're always thinking of new ways to do it. Basically, I've kept the Overdrive the same but the other models are open to flexibility.
What changes did the Explosion undergo before it became the Overdrive Special?
The active circuitry changed quite a bit, and the tone circuitry did also. But the concept of processing the signal post preamp stayed the same. Most other high-gain amplifiers use a pre-preamp gain boost, but I broke away from that quite early, in the late '60s. I found that trying to build the signal up before the preamp had a tendency to really overload the preamp, and you got nonharmonic tones and a very unmusical end result. Plus, you ran into a lot of vacuum-tube problems with harmonic's. So, what I wanted to do was get all that wonderful oomph and beautiful sustain and harmonic richness without the electronic troubles.
Were you making what was to become the overdrive before you made the Steel-String Singer?
The Steel-String Singer came later, but I actually started making a series of amplifiers called the Dumbleland in about '66, and I still make them. That was the forerunner of the Steel-String Singer. I didn't change a whole lot about that; it was a design way ahead of its time. It was too much power and too silky clean for people. It's perfect for Stevie Ray, though. He has a hard time playing an Overdrive.
Why is the Overdrive so sensitive?
It's a different kind of signal handling. In the Overdrive, I approach gain levels that are extremely intense; within the linear region, I have a signal gain capability of one million. So if you stuck 10 microvolts in, you'd get 10 volts back. And I do it with stability, and it's still very musical. The best way to approach an Overdrive is real slow. Walk up to it, look at the knobs, have it turned down real low, and then get a feeling for it. Learn what to do with your fingers to make it respond well. If you walk right up to it, it has a tendency to absolutely frighten some people. The secret control on the Overdrive's panel section is the ratio control, which controls how much overdrive is fed back into the circuit. If you turn that up, it's Rock City.
How different is the Overdrive Special you customized for David Lindley from a standard model?
I might have changed the value of a capacitor to some extent, so that it has a different treble response, but the circuitry is basically the same.
Lindley says that for certain sounds he's looking for, you sometimes borrow his guitar and Dumble for the weekend to match the amp to the guitar?
That's true. The amplifier responds so differently to each guitar that to get some effects, I need to use the player's guitars, instead of my own. That's one the great things about the amplifier; it doesn't modify any guitar into any one sound or homogenize it. It expands whatever you start with. The amplifier is a real important part of the sound regeneration system, but it needs to be very responsive to whatever the guitar is delivering. The philosophy I try to keep in the amplifier is that whatever you can hear in your head, this will help you get it.
Stevie Ray Vaughan calls his Steel-String singer the "King Tone Consoul."
There are some different things about Stevie's. His is set up more like a bass amp, modified to accommodate the guitar range. It's not the usual lead guitar "Singer" approach. One thing he liked was that he could turn the volume control all the way up and it didn't distort--it just got louder. He does make it distort sometimes because he has about 50 megatons of pressure when he attacks the strings [laughs]. He gets an incredible amount of signal out of his guitar, and most amplifiers can't take it. He did his first album with a bass amp I'd made for Jackson Browne.
Some players describe Dumbles as different, more powerful, more durable more efficient versions of a Fender Deluxe.
That's a good way to describe it--in a limited fashion. There are some great qualities to a small Deluxe. You get a great harmonic structure at a small acoustic volume. It's real pleasing, especially when you're playing by yourself. But that sound is not convertible into a group ambience--it's gone. So, in the respect that I try to get something comfortable and very musical, only in a bigger fashion, that's a good analogy. But the circuitry is not even close. I use vacuum tubes, and transformers and knobs, but the similarity stops there. To get the result I want, I have to use unique circuitry. It's my tone circuits and coupling circuits and the way I process phase-inversion.
Can you "Dumble-ize" a Fender amp to the point that it shares the Dumble philosophy and sound, or would it be a compromise?
It's a compromise. The actual physical construction of the Fender limits what can be done. In fact, after the last Steel-String Singer mod I did to David Lindley's amps, he no longer uses the Fender Bassman I Dumbleized for him. He wanted this luscious transparency and response--like floating in white clouds--and I came up with special circuitry. I can use a Fender chassis, but you have to rip everything off of it, fill in all the holes, and re-drill it. They're just a little bit too squashed. A distance of half a centimeter makes a big difference in the way something sounds. It's a science involved with what's called circuit constants.
Instead of a single bright/deep switch, most of your amps have separate bright and deep switches. Can you use both at the same time?
Oh, you bet. It gets luscious low notes that you could float on and beautiful, crystalline highs that are silky as glass.
How many watts are the various models?
The overdrives are 100 watts, but they're switchable down to 50, and I do make a special 150-watt Overdrive, which is a lot of fun. The range in power goes from a 25-watt recording amp called the Hotel Hog up to the 450-watt Winterland, named after the concert hall in San Francisco.
Click HERE for the photo associated with this text.
Could there be an ultimate amp for you, or are the Overdrive and Steel-String Singer too distinctive to be combined?
Well, the Phoenix series is where I've done that--so you can combine things--because it's a rack-mounted affair. You can by all the separate preamps, with or without overdrive, and a choice of 50-, 100-, or 150-watt power amplifiers, and hook them together. The overdrive section is expanded--instead of two overdrive controls, you have four.
After experimenting with various speakers, what do you favor?
I've gone with everything, there are a lot of things I still like. The most versatile is the EV. But all manufacturers, include Altec and JBL, make wonderful speakers that do specific jobs other speakers can't do. I divide speakers into two classifications: the efficient and the low-efficient. Both are very useable. Low efficiency speakers are things like Celestion and Jenson and PAS. Usually because of the physical construction, they don't get the same acoustic level per watt as the Altecs, JBLs, and EVs do. There's an advantage to that, because you can make the amplifier work harder to get the same acoustic level, and a whole different kind of harmonic structure results. I love the sound of JBLs, especially for chords, but I had a lot of trouble with 4" voice coil not traveling in a linear fashion. The actual coil would short out against the magnet structure. The Altecs didn't do that, so I was using them up until '79, when EV started coming out the the EVM series.
How does your philosophy on speaker enclosures contrast with other companies?
I think mine's different. I just don't believe in a baffle board with a couple of sides. Everything is designed to respond tonally. Even my open-back enclosures use air to the optimum. It's an ongoing process; I'm still finding out things that are useful. There's a definite technique to developing enclosures. Instead of increasing the output all from the front by feeding more watts in, I designed a special series of open-back enclosures so that there's actually an air pole inversion process--I make the air respond in an in-phase relationship, both in front and in the rear of the enclosure. So, from the same amount of speakers, it's almost a doubling of sound.
Does that change the tonal quality?
Yes. The low end is absolutely luscious. You feel like you're floating on a football field filled with marshmallows. And it gives a singe to the midrange that puts solos right out there. It works great for chords and solos, but especially well for slide. It's the kind of enclosure that Lindley and Lowell George used.
Is there a single emotional aim you're shooting for, or many?
It's a whole panorama. I don't believe in being confined. There are hundreds, perhaps thousands or millions, of valid guitar tones. When the air becomes electric, that's the right sound, no matter what the one is. It's that sound exciting the senses.
Guitar Player Magazine - September 1985
ToneMerc
Re: A MUST READ... AGAIN!
Post by ToneMerc »
talbany wrote:I would have to say that out of all the amplifiers out there I have analyzed and documented, Dumble amps without a doubt have been my most studied (with the help of many here) and played..Well over 12 or so years,and have built just about all the various ODS incarnations as well as the SSS,Ultraphonix,Hi-Gain,Hotel Hog,Explosion,Music Man,
Tony after building a few of the circuits, I came to the conclusion that IMHO his amps are the sum of small things. Now occasionally I will get hit over the head with one of these "small things" and have an ah ha moment.
Not long ago Jim (Omega amps) pinged me and shared one of his own ah ha Dumble moments. I mentioned to him that the first time that I had a conversation with Alexander (88') that I came away thinking this guy is 40% genius, 40% crazy and 20% butthole. However, after building a few of the amps, I don't think he was crazy at all! :D
Behind the marshmallow and crystal lattice fluff, there's some real genius.
TM
talbany
Post by talbany »
TM
Mike
I agree about all the small things that add up!!
I also think a big part of the Dumble genius/crazy is partly due to the fact that he was for me one of the first who understands the importance of harmonic content (fragile as it may be) but also was crazy enough to try an control it.. His use of NFB, PI,balance,HF taper, cap orientation,linear gain stages,use of cathode followers and to some extent even resistor choice..No one had ever tampered with the unknown like that (in guitar amps),especially with the SSS...The first thing I thought of when I fired up mine was DAMN!!..This guy is a frickin genius!!
lovetone
Great stuff
Post by lovetone »
This the first time I have read this interview very informative. Just had to read it over agin the man is a genius defiantly not crazy.
Which SSS did you build? I've been thinking about building one for a while, this has really spurred my interest.
talbany
Re: Great stuff
Post by talbany »
lovetone wrote:
SSS#002
Great Amp..
67plexi
Post by 67plexi »
Way Cool Tony on the #2 SSS, Thanks one more time for starting me on the 100 watt amps.
Now it's getting worse the amp sickness 150 watt amps. #060 ODSR got me thinking I'm sure that was a
test bed amp V-1 broke all the rules. Same thing with the 150 watt SSS amps it made no sense
MR.Dumble was breaking ground big time. I had a medical emergency yesterday all most didn't make it
I'm very thankful for life itself and friends I have made on TAG.
Steve. :D
telentubes
Post by telentubes »
Thanks Tony, Great to read that again.
hitchcaster
Re: Great stuff
Post by hitchcaster »
talbany wrote:
lovetone wrote:
SSS#002
Great Amp..
did you do the two rock type layout, or do dumble's goofy boards with the panel mount pre sockets in the middle of the boards?
talbany
Post by talbany »
67plexi wrote:Way Cool Tony on the #2 SSS, Thanks one more time for starting me on the 100 watt amps.
Steve. :D
Steve
I hope you are well.. Please be more careful!!
BTW>>I have a NOS Fenter 300 OPT I am dying to use..4X KT88's..I would love to do a Dumbleland next.. :D
Not sure how many times I've read Mr. Dumble's interview but I learn more each time I do and especially when you guys give such sage advice, thank you guys good posts.
67plexi
Post by 67plexi »
Thank you Tony, I'm chomping at the bit on the 150 watt amp.
I have that PS-300 OPT and some 200 watt OPT. I know that Fender used a twin choke with the PS-300
I'm thinking of upgrading that choke. One step at a time. I know that the 150 watt SSS has a loose B+
filter supply and a tight preamp I believe that the PS-300 will not distort at full output.
Think SRV.
Steve. :D
talbany
Post by talbany »
Steve ...Nice!!
The PS-300 comes in at 16lbs and my Hammond Pwr (500v Plates) I plan on using comes in at 17lbs..33lbs of Iron. :shock: This one will definitely piss off the wife, my Neighbors, The Band, and my dog,:lol:
jelle
Post by jelle »
I am cleaning up a set of 400PS trannies. 8)
glasman
Post by glasman »
I had heyboer build me a custom set of 200W iron. The power transformer has two sets of HV secondaries, one of the output section, the section is for he preamps through phase splitter. Dual filiaments, 40 v low voltage winding, 90V bias windings and a sledge a matic lol.
About 5 miles south of I-94
www.glaswerks.com
erwin_ve
Post by erwin_ve »
I always wondered how that is implemented in the ODS. Anyone got clues?
