Great point. I need to fuse before the switch. Thanks.trobbins wrote:My concern was that the FET drain is connected to chassis through the FET package rear metal (as I can't see an insulator pad). If that is the situation, then the FET source-drain is in parallel with the fuse - so the fuse won't function as intended for protection.
MOSFET B+ reducer
Re: MOSFET B+ reducer
Dorrisant - Did you ever try this? Can anyone verify that this does indeed work with a non-center tapped full wave bridge setup?dorrisant wrote:Could this be used with a TX that has no center tap?
Full wave rectifier produces too low of a voltage... appox 244vdc.
Full wave bridge rectifier produces too high of a voltage... approx 485vdc.
Looking for about 340vdc but it could be higher. I could drop it after the reservoir cap. Just wandering if this method would be appropriate here, or am i pissing up a rope. I really don't want to change out the PT... and learn a vital lesson at the same time.![]()
I don't see why it shouldn't, but....
Working on a salvage build right now and pretty sure I'm going to end up ~50vdc on the high side.
Deric®
Yes this technique will work for reducing the B+ from a FWB rectifier.
- dorrisant
Yes I did try it and yes it works as Martin said.
A big thank you to dorrisant for the nice PDF and DIYLC documents for the MOSFET B+ reducer, posted at top of thread.
- dorrisant
Thank you Xtian for stirring up this topic... much needed.
Also, just glad to contribute!
- dorrisant
I had some boards made... PM me if you are interested.
If anyone is offended, I will delete this post and move it to the FS section.
Awesome! Not offended!
Can we tackle the VVR for fixed bias next?
I considered doing this but again held off as a courtesy to Dana who piped up when this discussion was started.xtian wrote:Awesome! Not offended!
- dorrisant
Someone is already doing it...Colossal wrote:I considered doing this but again held off as a courtesy to Dana who piped up when this discussion was started.
http://grangeramp.com/shop/index.php?ma ... cts_id=567
Thanks for the Granger tip! Pretty good kit price.
Yeah, he's been doing it for a while. There are a few other guys out there as well.
- dorrisant
Further question for the brains...
How would you apply this circuit to a voltage doubler? Or did I just spin for a whammy?
The CT is the usual insertion point. Without a CT, the rectifier ground is the insertion point.
With a voltage doubler as in the Fender Twin 135w UL...
The rectifier is grounded. The high voltage CT is fed to the voltage divider/balancer floating at half of HT to ground. Would you insert it at the rectifier ground or just don't use it?
I'm a bit confused here.
You would insert the reducer between the negative side of the bridge and ground. The CT will be at the half-way point between the B+ and the negative voltage at the FET source (not at half of B+), so you can't connect it to the center of the cap stack. I would use balancing resistors (which are already there in the schematic shown), and leave the CT unconnected.
