A Collection of #124 Information (Schematics, Layout, etc.)
Re: A Collection of #124 Information (Schematics, Layout, etc.)
Tony updated the layout once or twice and fixed most if not all of the errors as identified in the thread above. Ratio/Level is ok, the B+ 4-5 is updated, (slightly off at the ground side of the cap, but easy to figure out). R/J switch is the same, FX loop is the same.
I do not think it's a good idea to have anonymously edited versions of the layout floating around.
There is nothing wrong with that layout.
Tony asked me to edit some things on it when he was busy.
Some things were not clear such as the OD pot labeling, some grounding, the OD, PAB Switch grounding, the FX Loop network and feedback loop ground.
Tony may have used one of my updates for his latest version.
But this last one is one I made for myself from the Visio file.
jlatrace
Post by jlatrace »
Does anyone have the wiring diagram for the JAzz/Rock switch wired to engage the PAB?
jlatrace wrote:Does anyone have the wiring diagram for the JAzz/Rock switch wired to engage the PAB?
Use a center "off" (on-off-on) switch. That is all you need.
Strodden
Post by Strodden »
Hey all! Just found this site and think I'm going to be addicted very fast :) Can anyone tell me how many watts this #124 is? Also, (possibly ignorant question) is this meant to be made as a "head" or a combo style? Does it not even matter? I'm trying to get educated about this subject...
Joost
Location: The Netherlands or Holland. Whichever you prefer
Post by Joost »
Strodden wrote:Hey all! Just found this site and think I'm going to be addicted very fast :) Can anyone tell me how many watts this #124 is? Also, (possibly ignorant question) is this meant to be made as a "head" or a combo style? Does it not even matter? I'm trying to get educated about this subject...
It's a 100W head that can be switched to 50W but it can be a combo if you make a different combo shell for it. The outer shell has nothing to do with the chassis you use to build the amp in.
Since most of us like a colder bias on the ODS style amps, it probably isn't a full 100w and who plays full out anymore anyway?
But they are indeed loud and sound great at just about any volume.
Sven
Post by Sven »
delete
Bombacaototal
Post by Bombacaototal »
Does it make different tonewise having the bright cap as silver mica instead of ceramic?
splgeo
Post by splgeo »
yes
Bombacaototal
splgeo wrote:yes
Thanks a lot
Would you venture to explain the difference
dorrisant
Post by dorrisant »
Ceramic may sound a bit grainy and possibly can be heard as harsh... Silver mica might sound clearer. Neither are bad and in some instances you may not be able to detect a difference. Try it for yourself and hear.
Bombacaototal
dorrisant wrote:Ceramic may sound a bit grainy and possibly can be heard as harsh... Silver mica might sound clearer. Neither are bad and in some instances you may not be able to detect a difference. Try it for yourself and hear.
Awesome
Bombacaototal
Structo wrote:Here is a #124 layout that I have adjusted over time to reflect what has been discussed before.
On the tonestack Im in doubt between keeping the middle cap .01uf with 150k slope or having it at .047uf with 100k slope (both with the 250ka pot)
I've done some simulations on the duncan tonestack but was curious for opinions
jelle
Post by jelle »
Wow, how do you simulations on that tone stack calculator? Did the Dumble tonestack get added?
