Mystery find
andresound
Mystery find
Post by andresound »
Hi Guys, picked this up last week. It will arrive this week. Besides great donor PT and OT and loaded with a 12” alnico... anyone familiar with this amp from 1946?
TUBEDUDE
Re: Mystery find
Post by TUBEDUDE »
That looks like a great refurb project. What tubes does it use?
andresound
Re: Mystery find
I will only know for sure of tube compliment when I receive the shipment. But it looks like a pair of RCA 6v6’s and maybe 6SN/L pre tubes. Will revert once I receive.
Coyotesgator
Re: Mystery find
Post by Coyotesgator »
Looks like someone took a grinder to the trans corner.
What Happened?
Who let the magic smoke out?
andresound
Re: Mystery find
Coyotesgator wrote: Tue Jan 22, 2019 7:10 pm Looks like someone took a grinder to the trans corner.
Now that you pointed that out.. it looks like both trannies have been subjected to a grinder!!! Might have something to dude with the cabinet.
Davidg
Re: Mystery find
Post by Davidg »
Well it is a Wizard so it should have a great AC/DC tone. I guess this must be the first one. Lol
If Hendrix had lived would he have been as good as EDDIE? (Shaver that is)
andresound
Re: Mystery find
Well.... I picked up the delivery today and had a quick peek at the wizard. The cabinet is made out of VERY thin ply 😳!! The amp is from 1946. The power amp looks to have TWO mains transformers that look to be original. I would think that one was for powering the original field=coil speaker? (Seems too large). The transformer underneath, is the OT. Will revert with more details and pics over the weekend.
Have a great weekend!
andresound
Re: Mystery find
Some pics of the bigger of the two PT’s. Looks to be 350-0-350 @ 120ma.
This PT was located next to the rectifier (5U4) and power switch and fuse.
andresound
Re: Mystery find
The smaller of the two PT’s looked like this (325 0 325 @100ma), and was connected to a 0Z4 rectifier (cold cathode), and had this “VIBRATOR”, which I have never seen before (dont know what it does)!
Re: Mystery find
Looks like it has two high voltage supplies, so it can run from a 6V DC source. Vibrators were common in auto radios and home radios when no AC power was available. It's a low frequency electromechanical switch mode power supply.
Re: Mystery find
That electro-mechanical vibrator was commonly used in autos with a 6V battery system and a tube radio. The vibrator was part of the radio. It would take 6VDC and chop it up by vibrating a switch contact, which produced a rough square wave AC voltage that was fed into a transformer. The transformer would step up the voltage which would then be rectified to produce B+ voltages suitable to operate the tubes in the radio.
That vibrator kinda suggests that the wizard could also be operated from a battery.
andresound
Re: Mystery find
martin manning wrote: Fri Jan 25, 2019 12:04 pm Looks like it has two high voltage supplies, so it can run from a 6V DC source. Vibrators were common in auto radios and home radios when no AC power was available. It's a low frequency electromechanical switch mode power supply.
Thanks Martin and Slucky. Does that mean the second smaller but still beefy PT does not have a 240v primary?
andresound
Re: Mystery find
BTW.. this smaller OT looks cool from WODEN
Re: Mystery find
That would be my guess.
