It’s a 40W amp running with 2 x EL34s and 4 x 12AX7s. Two channels, Ultra and Classic, footswitch to go between them and a footswitchable solo volume boost. All crammed into a 50W chassis (Can’t make things too easy!).
The Classic channel has a Bright switch and a switch to go between Clean and Crunch. This is basically the same as the Soldano clean switch, it just adds a voltage divider in to cut the signal. This channel reminds me of a JTM45, although with a tad more gain.
The Ultra channel has no switches, I wanted to keep this channel nice and simple. My goal for it was a late 60s Marshall tone on steroids. I feel I’ve finally achieved that now, but it has taken quite a few months, a lot of experimenting and a big learning curve. I’ll explain in another post the process I went through and also hope to get some recordings done soon.
And in case you're wondering, the Avro Vulcan is my favourite aircraft, hence the name
