NFB and presence control on a standalone preamp?
- jarrodthebobo
Been screwing around with my preamp build which has undergone a boatload of changes... Was just wondering if anyone had any sort of idea to how I can implement this?
In my SE builds Ive added,nfb via tapping off the OT and sending that to the cathode of my last triode which I use as a "fake pi"... But with no OT here, is this possible?
Thanks.
Thanks.
Re: NFB and presence control on a standalone preamp?
Do you want to have negative feedback on which stages of the preamp and to obtain what?
It is just to have a presence-like equalisation?
- jarrodthebobo
If you mean the frequency part of "what you'd get in a full amp", you can use a rheostat (and a resistor in series) to partially bypass a cap on the cathode of the last stage.
If you mean the overall sound (harmonic complexity, dynamics, etc...) of a power amp, it won't work.
- jarrodthebobo
So, without implementing NFB? Would this cap and rheostat combo be bypassing the last stage such as a normal cathode bypass cap?roberto wrote: ↑Thu May 28, 2020 8:33 am If you mean the frequency part of "what you'd get in a full amp", you can use a rheostat (and a resistor in series) to partially bypass a cap on the cathode of the last stage.
This is one option, otherwise you can have a voltage divider with a cap and the rheostats to have the same shelving effect.
I've posted a thread with something similar but for a different purpose, months ago.
- jarrodthebobo
Gotcha! I dig some digging around here and the sloclone forums and found something that ended up working pretty well for what I wanted. I'm currently rendering a video including some audio of the finished product along with some info about the topology. I keep promising to make a schematic of this thing for others to screw around with, but always end up changing the preamp; hell, just today I finally decided to add a 3rd 12ax7 for some cathode follower action
- jarrodthebobo
For anyone interested, here's what I needed this idea for. Although I didn't end up implementing NFB in the way that I thought I'd be able too, I think the result was pretty good.
Thanks for the help, Roberto!
Now I've got what you are looking for.
For that sound, just use a standard plexi preamp, then add after the eq two triodes in parallel, 27 to 47k on the plates, 3k3 to 8k2 on the cathodes.
Snubber some highs if needed. You'll find two threads on it on sloclone.
- jarrodthebobo
That sounds interesting... I'd never thought about running two triodes in parallel after the tone stack... What should I search for on the sloclone forum? I wanna see some more of this haharoberto wrote: ↑Sat May 30, 2020 6:40 am Now I've got what you are looking for.
- jarrodthebobo
Been messing around a bit more and swiped the last two stages of the Bogner Fish in order to try to implement presencr how it was done in in that circuit; and I must say its much more effective than I expected. The only oddity I've noticed is that when the presence is maxed, it seems more like a mid boost and also increases gain quite a bit vs. When its backed off. Its real nice when I'm going for a soaring lead tone, but If im trying out some " chigga chiggas" having the presence up high adds too much mids and I loose the "chug". Turning it down brings it back back some gain is lost.
How exactly does this presence circuit work? Is it utilizing local feedback?
The Bogner Fish preamp takes use of a local negative feedback around the dc coupled cathode follower.
On one extreme setting, the presence control takes out the 22n cap that and basically feeds back the signal in full range through 2Meg feedback-R.
On the other extreme highs and mids are dimmed so only bass frequencies are fed back which causes an emphasize on highs and mids but it really is more of a bass cut.
I wonder how the stage reacts under heavy overdrive under full range feedback setting. When the stage clips, doesn't the feedback falls apart and even more distortion is generated?
