Steel String Singer #002 Chassis/PCB Boards - EU
List tube amp related items you wish to sell or trade. Private sales only. No dealers or manufactures.
erwin_ve
Post by erwin_ve »
Placeholder for SSS #002 Chassis & PCB availability. Updated july 25, 2023
Chassis Specifications:
Material: 3mm thick 5754 H111 Aluminum - High conductivity and extremely good corrosion-resistant qualities.
Bend Radius: 3mm
Overall Chassis Dimensions: 603,3mm x 204,5mm x 63,5mm
127mm Chassis mount spacing. I found a fabricator to work with for a headshell, https://www.elfring-amps.com/nl/
Welded vertical supports (this thing will NOT flex at all if you twist it :D )
Optimized for PCBs (no drilling required!) and still compatible with the point-to-point eyelets Ryan designed and Hoffman Amps makes
https://el34world.com/Forum/index.php?topic=24843.0
This run of chassis are powdercoated with black silkscreen markings and fonts that looks like #002 without the "Dumble"name.
-Powdercoated finish chassis, with silkscreen artwork - €275
-SSS #002 PCB set designed by me- €150
-Shipping costs are variable in the current world market. For details PM or e-mail : info at e-noize.nl (for spam reasons you can figure out the @ )
-Note to US and other non-EU customers; I can ship worldwide, the chassis have blank voltage and fuse markings!
-Latest run have IEC adapter cutout, the original AC inlet is obsolete and not useable outside the USA.
-Latest run have mounting holes compatible with the mk1000-3 anchor nuts.
-Latest run has a optional pcb for a bipolar bias voltage suppy(for the cathode driver tube), this is not-tested yet! Only on request and at your own risk.
Layout and schematic: https://ampgarage.com/forum/viewtopic.p ... 67#p431767
Erwin
erwin_ve
Re: Steel String Singer #002 Chassis/PCB Boards - EU
Post by erwin_ve »
Pics: board sets come unpopulated for the record
erwin_ve
Post by erwin_ve »
only 4 sets left...
erwin_ve
Post by erwin_ve »
3 sets left...
norburybrook
Post by norburybrook »
stop it....... :mrgreen:
M
didit
Post by didit »
norburybrook wrote: Tue Jul 21, 2020 8:44 am stop it....... :mrgreen:
We know you really want to do it ..
erwin_ve
Post by erwin_ve »
I repeat 3 left... :D
Colossal
Post by Colossal »
erwin_ve wrote: Tue Jul 21, 2020 9:08 pm I repeat 3 left... :D
didit wrote: Tue Jul 21, 2020 7:32 pm
Hahaha, you guys are a bunch of enablers. Good thing this is Amp Garage and not Crack Cocaine Garage.
C'mon Marcus...everybody's doing it...
norburybrook
Guys
I had all the rest of my years work cancelled last week so my next gig is now march 2021. By then I will have not worked for a year!
They've opened the theatres from 1st of august but no one's going to promote a show with social distancing rules, it's not financially viable. However by opening them it lets the govn off the hook in regards to paying furlow to all involved :( I've made a professional living as a musician since 1980..this is all really worrying.
anyway, not to derail Erwin's wonderful contribution to the amp world :D
come on people snap up the last 3.
M
erwin_ve
Post by erwin_ve »
1 reserved, 2 sets left...
erwin_ve
Post by erwin_ve »
Sold out. I'll do another run in september.
I'm creating a list for people that are interested. So please don't hesitate to reach out!
Erwin
erwin_ve
Post by erwin_ve »
Quick heads up: pcb boards are available.
Chassis are delayed, but should be soon.
I'll post when they are ready.
Post by Mark »
The power outlet hole isn’t required in Countries like Australia. Do you have a cover for the hole?
erwin_ve
Post by erwin_ve »
Mark wrote: Wed Nov 04, 2020 6:33 am The power outlet hole isn’t required in Countries like Australia. Do you have a cover for the hole?
Hi Mark,
Exactly my thoughts. In my own build I made a IEC adapter for that big hole and used the cable inlet near the power tubes as a B+ fuse.
If anyone want a Iec adapter I can add it for free.
Erwin
erwin_ve
Post by erwin_ve »
Hang in there guys:
During fabrication something went wrong with the coating. The fabricator is handeling the issue so it will take some time :roll:
Erwin
