5E3 summary of small issues
fredouille
Post by fredouille »
Hi all, I built directly a modulus kit with mods..
I have small issues on which your comments are welcome
I moded the diode protection + diode switch.. the pre rectifing diodes make me loose a lot.. 400v with no 6v6 and 300 loaded !!!... 450 with diodes and 380 loaded.. a bit low no ? looks like nothing to do or removing pre diodes
negative feedback goes directly into oscillation (robinette mode 3 positions 56K on 8 ohm output), I suspect of course out of phase signal, so to do : invert output transformer to plates wires, can you confirm ? (I will check with oscilo of course the phase between input and output before doing the change, it is not easy as I have the half power mod, a lot of wiring there)
small disturbing stuff.. between channel isolation.. I have signal from 1 channel to another even not plugged on the right channel.. I will check grounding of each jack, maybe global grouding issue
outside this, guitar playing speaking, very powerfull and overdriving easy, bright channel on humbucker impossible to get a clean sound. interesting amp but no reference to compare. I tried with a dussenberg guitar which as a lot of gain, no telecaster available here
not at the level of bassman 6g6b or blackface still, here I can compare as I have 2.
need to check another cab, I tested on a laney 2x12 a bit dark, will test later on fenders ones
fredouille
Re: 5E3 summary of small issues
update for myself in did negative feedback issue solved by crossing wires
debugging noises a bit.
none of the B+ have any V AC, neither anything visible but see attached
blue is output.. no signal injected, all the ground, volume a 0 and tone at the middle
yellow is where I catch first time 50hz in tracing signal which on V2A plate (12AX7).
around the plate I get small 50hz.. on B+3 flat.
on grid flat also..
cathode flat also..
interesting where this 50hz could come from.. filament?
in did the mod for negative feedback arrives on the cathode and some wires are running a bit far but again nothing on the cathode..
fredouille wrote: ↑Sat Jul 27, 2024 1:52 pm interesting where this 50hz could come from.. filament?
Most likely. Rectified DC voltage would be 100 Hz, and sawtooth in waveform.
fredouille
martin manning wrote: ↑Sat Jul 27, 2024 2:06 pm
yes.. so this 50hz is caught by induction from filament, still the level is low.. 0,0Xmv..
Can you post up several good pictures of the guts?
fredouille
Stevem wrote: ↑Sat Jul 27, 2024 6:49 pm Can you post up several good pictures of the guts?
I will look but it is difficult to see around power tubes.. due to added switches on the rear
no comments on the low B+ voltage ?
The low V+ is why I asked what is the idle current the output tube is pulling.
fredouille
Stevem wrote: ↑Sun Jul 28, 2024 11:16 am The low V+ is why I asked what is the idle current the output tube is pulling.
not much I have 16v on the cathode resistor.
so 300 - 16 / 250 ohm
I will test something I'm suspecting that maybe I lost 1 of winding in high voltage transformer (dead diode or bad solder or bad tranformer)
Stephen1966
Post by Stephen1966 »
A schematic with your mods might be more helpful here. Not assuming you've done anything "wrong" just, it's a whole lot easier to reference from.
What is the voltage at the speaker output jack? With a signal and the amp dialed up to clipping.
Stephen
www.primatone.eu
fredouille
Stephen1966 wrote: ↑Mon Jul 29, 2024 8:53 am A schematic with your mods might be more helpful here. Not assuming you've done anything "wrong" just, it's a whole lot easier to reference from.
yes thanks for not assuming, but I first do assumed that I was wrong it is normal
update is.. without load. HT disconnected (standy is connected before B+)
transfo output 300 V on each side, so transfo is ok, but should deliver 400 V
after each diode I have 180v around
after tube rectifier I have 300 v. which looks logical voltage drop.
without tube rectifier but with diodes 350 v which is logical.
in terms of schematic the mod is here : https://robrobinette.com/5e3_Modificati ... ier_Switch super simple
what I'm sure is that I was getting 400 V or more before the mode, but without power tubes. power tubes in standy are draining only heaters so.
but I will try to remove them to see
at the end I may remove the first diodes and keep the diode rectifier option .. but I liked the idea to protect the rectifier
update : I added a 500K resistor in // on the 1st cap for voltage draining, might affect voltage divider, but not on the first point B+ I guess
fredouille
last update
on the 2 diodes 1N5408 i have DC drop 10v without the rectifier tube.. 20v with the tube.
I guess the diode have an issue.. diode tester give them at 0.5
I will remove and check.
unless I forgot in my electronic lessons.. I should not have more than 0.5 DC drop
Where exactly is your standby switch? When you are measuring the B+ in standby is there a reservoir capacitor connected at the rectifier output? Post a schematic of what you have built.
fredouille
martin manning wrote: ↑Mon Jul 29, 2024 5:26 pm Where exactly is your standby switch? When you are measuring the B+ in standby is there a reservoir capacitor connected at the rectifier output? Post a schematic of what you have built.
no I have standby switch just out of rectifier
I removed diodes now before rectifier, on startup I have 380 then doing down to 300, I guess draining current
16v on cathode on 250 ohm which is not a lot 55% dissipation which is too low.
I thinq is transformer is set for 240v , I'm on 220.. so on secondary I have the same difference + the freaky diodes which i guess were fake
What voltage do you get with the tubes removed and the standby on "play?" This will give you the correct no-load condition. With no reservoir capacitor connected you are measuring average DC of a FW rectified sine wave.
fredouille
martin manning wrote: ↑Mon Jul 29, 2024 6:35 pm What voltage do you get with the tubes removed and the standby on "play?" This will give you the correct no-load condition. With no reservoir capacitor connected you are measuring average DC of a FW rectified sine wave.
i can't disconnect caps
without power tubes 480 v. premap tube plugged. I loose 180 on load.
