Overdrive Special 50W to 100W with ECL82 Pentode Reverb
- Hendrixianer
My Build and Interpretation of an Overdrive Special #102,with ECL82 Penthode Reverb
DIY Amps: Marshall JTM45,Orange Grafik II 50W,Some 18W Marshalls,Dumble ODS 50W,Hiwatt DR103,Madamp G3 Blues,Dumble Steel String Singer, Fender Standalone Reverb 6G15,a few Hundred Pedals,like Uni-Vibe,etc,etc...
Re: Overdrive Special 50W with ECL82 Pentode Reverb
Nice looks good. How does the reverb sound?
- Hendrixianer
2 others liked this
Reverb sounds Beautiful,lush and Full with a 3-Spring Tank,its way much better than a 12AX7 one Tube Reverb !
- Hendrixianer
Conversion to 100W,and Footswitchable Fet-Boost,New 5-Way Footswitch:
Nice build!
I like the ECL82 idea for the reverb, it certainly economizes on socket space.
Gibson used the similar solution for the reverb in their Falcon amps from '60.
7199 tube was used, triode + pentode in one tube.
- Hendrixianer
Don´t knew that before,first I try a 12AX7 Reverb,but Tube was driven much outer Limits,so I end up calculate loadlines for the ECL82 and decide to go with it,much better,technically and musicallly.
- Hendrixianer
Yes,i´am with you.
- Hendrixianer
Re: Overdrive Special 50W to 100W with ECL82 Pentode Reverb
New Faceplate added:
