Marshall 100watt Plate voltage
Marshall Amp Discussion
flemingmras
Re: Marshall 100watt Plate voltage
Post by flemingmras »
Roe wrote: ↑Fri May 08, 2026 6:19 am As PDF64 explains above "If the [screen] dissipation is below the limit, eg typical fixed bias idle, then the voltage can be above the limit. With saggy supplies, things can pan out ok. The issue is both voltage and dissipation being above their limits simultaneously."
So the 425v limit does not matter too much. But you need 1k+ screen resistors
I wish we still had access to the Metro forum. I recall several years ago being part of a thread discussion regarding this very issue. Tubes were redplating because the high voltages of yesteryear were being copied, but the regulation spec of the modern transformer builds was too tight for it to sag enough to work.
Roe
Post by Roe »
flemingmras wrote: ↑Fri May 08, 2026 1:14 pm
yes I started a long thread on this as well as a shorter one on this board, see https://ampgarage.com/forum/viewtopic.p ... 2&p=109098
with the 1.7k primary the plates must sag to 420-30v to avoid redplating
flemingmras
Roe wrote: ↑Fri May 08, 2026 1:20 pm with the 1.7k primary the plates must sag to 420-30v to avoid redplating
The B+ must sag. The plate voltage alternates under signal, and, at the peaks, will go as low as the load line allows (down to the crossing point).
If the load were ideally matched for the voltage, you'd maximize power transfer to the load while reducing power wasted across the tube, which would also reduce the redplating.
eddiep1966
Post by eddiep1966 »
Update:
Ok the Hammond transformer was not at spec. So order a new tranny. I have used Hammond for years and never had an issue. Guess there quality control is going to crap to.
eddiep1966 wrote: ↑Sat Jun 06, 2026 12:54 am Update:
How so? What did you measure to determine this?
eddiep1966
By using a variac and monitoring voltages.
eddiep1966
Sorry Martin guess I read your response wrong. Spec's sheet states 120v on primary places 350v on secondary loaded. lt places 388v on secondary under load. Of course when applying my full wall line voltage 125.5v when test was conducted that sent the secondary higher. To get the secondary down to 350v had to turn the variac down to 108v but then it lower heaters volts down to 5.1v.
No problem, so if you correct for the wall voltage did it produce the correct no-load voltage? That would be the easiest thing to check. You could also look at the DC resistances and compare to the spec sheet.
eddiep1966
Not at the amp right now but I beleive it was 394v. I'll check the ohms tomorrow.
eddiep1966 wrote: ↑Sat Jun 06, 2026 8:04 pm lt places 388v on secondary under load.
It requires 420mA load current to bring the secondary voltage down to 350V AC.
That's an 833R load resistor dissipating 147W!
The no load secondary voltage is 370V AC +/-2%
https://www.hammfg.com/files/parts/pdf/ ... 1697661948
eddiep1966
Update: Well got a new tranny in it and it sounds great. Voltages are good now tubes and screens are happy. Had one custom made at Pacific Audio Magnetics. Basically it a stand up version of their 100watt plexi replacement.
Thanks to all that gave input and suggestions.
On to the next build.
