I procrastinate on these kinds of projects, mostly because I'm not all that great at mechanical CAD drawing. Then there's all the measuring and looking stuff up to make sure the dimensions are right. And I use freeware CAD because it is cheap, despite often annoying.
Was about to finally get this done, as I've done many such exercises before and I thought, let's get AI to do the work.
So I instead of measuring anything, or looking up data sheets. I just prompted (the paid-for version of) ChatGPT:
That's it. I'd already looked these up as equivalents for the transformers I had sitting on my workbench.Design an adapter plate to fit a smaller power transformer onto a chassis that is cutout for a larger transformer. The existing chassis is cut and drilled to fit a Hammond 290D2X power transformer. The target transformer is a Hammond 290XX and the plate should be cutout and drilled to fit.
Over the next two minutes, ChatGPT searched the web, found the mechanical drawings from Hammond, analyzed the drawings from PDF, collected the dimensions, then designed the adapter plate.
I already knew the depictions at Hammond didn't indicate the size of the transformers that protrudes through the chassis, just the exterior dimensions, and the mounting stud locations.
ChatGPT got it pretty close to right. It had to guess on the center cutout for the new transformer.
I printed the PDF file, went to the bench, took some physical measurements, scribbled down on the drawing the new desired dimensions for the center cutout, the outside cut, and to increase the bolt holes.
My next prompt:
And 13 seconds later, I had a PDF, an SVG and a DXF file.Thanks, that's pretty close. Make the following revisions: Center cutout opening 2.250 x 1.8750. Revise all holes to 0.250 diameter, outer dimensions 4.125 by 3.3750, and select a suitable exterior radius for the outside corners.
That's it. Done.
Then we discussed material options and thickness, versus weight and impact resistance, finish options and available vendors.
I loaded the DXF up in LibreCAD and validated the dimensions, then logged into SendCutSend, dropped the DXF file on the quote page and a few clicks later, ordered my adapter plates. The preview was fine, and I ordered them. Should be here in a week.
Took me longer to write this post.
