I'm about to order some fuses and I would like to know if 6.3mm x 32mm (presumably the same as 1-1/4" x 1/4") is the correct size for an early 80s JCM800 Mk2 Master Model 100W Lead.
These ones seem to be good quality (250V):
SIBA GZ series (70-059-61/1A): Slow blow (T), 1A
SIBA GZ series (70-059-61 2A): Slow blow (T), 2A
Is it ok (or even better) to use ceramic fuses? I need fuses for other amps and they are only available in this material.
Edit: These fuses fit perfectly. I used a SIBA 70-059-60/1A (Fast 1A) for HT.
Fuse size for early 80s JCM 800
Re: Fuse size for early 80s JCM 800
I don’t believe that the 1 amp fuse for the HT ( B+ ) should be a slow blow.
Thanks, I'll stick to F for HT fuse.
Although the amp came with a F1A fuse in HT (not sure if it has been replaced), both the manual and the rear panel indicate T1A.
https://el34world.com/charts/Schematics ... er_amp.png
I'm unclear whether those SIBA GZ fuses are made to IEC60127 or UL248, the datasheet doesn't really clarify.
From the technical documentation (page 4):
Standards
The following important international and national standards apply:
70-059-61/1A
EN 60 12
IEC 60 257
CEE 4
DIN VDE 0820, Part 1
DIN VDE 0820, Part 2
DIN VDE 0820, Teil 3
UL 248-14
UL 512
CSA Standard C 22.2 No. 248.14
So no IEC60127 / UL 248 compliance... Will look into this when purchasing fuses, thank you. There are more alternatives in 5x20mm size.
Standards
70-059-61/1A
EN 60 12
IEC 60 257
CEE 4
UL 248-14
UL 512
