Doug Doppler w/ Henry Keisers Dumble
boldaslove6789
Post by boldaslove6789 »
Here's a Link for the 4 part series w/ Henry's Dumble, He's renting it. Doug Doppler is a killer Session guy. He had a lot to do w/ the Rockband/Guitar Hero recordings ( yes I know Guitar hero,what a joke LOL)
http://www.youtube.com/watch?v=34Y3lHpK ... re=related
Sounds like Henry's amp is got the Mojo in part 4.
Last edited by boldaslove6789 on Sat May 15, 2010 6:39 pm, edited 1 time in total.
UltraHookedOnPhonix
Re: Doug Doppler w/ Henry Keisers Dumble
Post by UltraHookedOnPhonix »
Cool Vid!
Interesting to note that the R/J switch is a three way switch with PAB in the middle spot.
dogears
Post by dogears »
I was underwhelmed with the recording quality and overall presentation of the four parts. Nothing grabbed me.
Just sayin'
talbany
Post by talbany »
boldaslove6789 wrote:Here's a Link for the 4 part series w/ Henry's Dumble, He renting it. Doug Doppler is a killer Session guy. He had a lot to do w/ the Rockband/Guitar Hero recordings ( yes I know Guitar hero,what a joke)
Very COOL 8) 8)
Doppler does a great job!! an in depth demo of the amp and is a cool dude.. He goes through all the pickup configurations on the various guitars demos the FET input..uses different guitars and is a solid player.. I liked the center position of the Jazz Rock that bypass the TS so he says is cool.. The Deep switch doesn't seem to act like the traditional Deep switch posted here maybe converted to the later mid boost..Anyway good demo I recommend it .. Andy's Plush pedal also sounded good.. Nice job Andy..Thanks for posting!!
gilgalad101
Post by gilgalad101 »
So how would the PAB be wired to the Rock/Jazz switch middle position?
talbany
Post by talbany »
gilgalad101 wrote:So how would the PAB be wired to the Rock/Jazz switch middle position?
Try it.. If you use the same switches Dumble did you can gently find the spot in the middle of the switch where it doesnt' make contact with either pole and essentially becomes a center off and will stay there .. You can hear the boost effect..Pretty cool..
gilgalad101
I'm in the process of building my first amp, so I can't try it. I wasn't sure if the wiring was different or not. Thanks!
talbany
Post by talbany »
gilgalad101 wrote:I'm in the process of building my first amp, so I can't try it. I wasn't sure if the wiring was different or not. Thanks!
I don't know either however it does act like the boost on the video.. Those 3 pos switches are generally center off so I don't see how it could be wired any different unless it's a TPTT which I highly doubt.. Good luck with the build..
TheHandsomeOrk
Post by TheHandsomeOrk »
No diff in wiring, even with a standard DPDT switch you can stiil get the boost by tweaking the switch between rock/jazz mode ( you know, like they used to do on the old 3 pos strat switch before the 5way switch came into being). Works on my amp fine, maybe I'm using cheap switches :wink:
