Good 1x12 speaker extension cab for ODS?
Last year I built a ceriatone 50 watt ODS style amp. I want to get a 1x12 extension speaker cab that I can put an EV12L style speaker into (maybe I'll get a WGS12L, I hear they are good).
Does anyone know a good place I can get such a speaker cab? Ideally I'd like it completely finished and tolexed, but unloaded. I am considering buying the extension speaker cab from Ceriatone, but that shipping from Malaysia is always expensive.
Re: Good 1x12 speaker extension cab for ODS?
Depends on where you are. For Europe id say give Tube Town a try.
In the UK there is Zilla and Modulus
- norburybrook
I've used these guys when I couldn't be arsed to make my own.
https://afcustomcabinets.weebly.com/dum ... -cabs.html
M
M
Sorry, I should have said, I'm in the northeast USA.
http://www.trmguitarcabs.com/
I've only bought one, and it was unfinished, but I'm a fan. He's in New Hampshire if that makes any difference.
I’ve had TRM build me a couple of custom cabs. He was very willing to work with me regarding the unique design of a pine vertical 2x8” tube up combo cab with “3D style” side vents—which I finished with flame.
Definitely worth checking out.You do not have the required permissions to view the files attached to this post.
Thanks, all!
BTW, was there ever a standard size 1x12 speaker cabinet for the Dumble ODS? I see that someone on theampgarage has previously drawn up some plans:
https://ampgarage.com/forum/viewtopic.php?t=28332
http://ampgarage.com/forum/files/dumble ... ns_119.pdf
In these plans, the cab is 20"x20"x12.75"
Is that standard? or is there no real standard?
It seems there is not a standard in modern production at least, but AKAIK there are 3 more or less standard sizes:
- Vented box with EVM12L, like the one Carlton used;
- Square oval back 1x12", same width as the head shell;
- A wider oversized 1X12", but that might be just modern non-Dumble production.
FWIW, I made a 24.25″ WIDE, 18″ TALL, 12″ DEEP 1x12" modelled after a Two Rock 1x12". Very lively and big sounding for a 1x12".
Here is the link to the ampgarage Dumble 1x12 plans that I used.
Is that cab really suitable for an EVM12?.... There is amo a reflex cab designed for the EV....
I love EVM12L style speakers in all kinds of cabs, open back, closed, whatever.
