Bluesmater finished
Blues Hound
Bluesmater finished
Post by Blues Hound »
Finished a 100 watt Bluesmaster
Here are some pictures.
This is fast becoming my favorite circuit, Considering removing the FET and installing a 150K resistor to ground.
Getting the Clean and Overdrive channels to balance took a little bit to get, but it is a tone machine.
6L6GC's are Tong Sol
V1 Short Plate GE 12AX7
V2 Long Plate Mullard 12AX7
V3 JJ 12AX7LPS
wsaraceni
Re: Bluesmater finished
Post by wsaraceni »
that looks really clean. id love to build something similar but im definitely intimidated to start it
Blues Hound
Thanks, if you take your time, you could do it, this place has a wealth of knowledge and great people.
dorrisant
Post by dorrisant »
Very nice!!
dbharris
Post by dbharris »
Great looking build!
-Dan
jrdamien
Post by jrdamien »
That Bluesmaster looks awesome! The 6L6GC’s from Tong Sol should give you plenty of punch
rccolgan
Post by rccolgan »
Incredible!! Congrats
Ryan
https://www.thetonegeek.com/
Raoul Duke
Post by Raoul Duke »
Looks great! I bet it sounds fantastic as well.
Great job 👍!
Marc
Matt J
Post by Matt J »
Very nice!
I haven't ventured into Bluesmaster territory yet but that build is very inspiring!
I bet it sounds awesome!
Matt J.
GAStan
Post by GAStan »
Nice looking build. Well done!
Glenn
I solder better than I play.
Blues Hound
Thanks everyone, this has become my new favorite circuit, Clean is great with a Strat, Tele, Les Paul, Overdrive is really sweet.
Considering changing the bright cap to 100pf or 250pf, cannot really hear a difference with a 47pf cap.
Added a 3.9k off of the Mid pot to try and tame the Boost as it is crazy loud, any suggestions for that? I saw in another thread where there a trimmer added to the mid pot, but I don't the value that was used.
My 124 clone is a great sounding amp has a set of matched Phillips 7581A, the 102 is also a really great amp, but this is something more.
Have another PT and OT, considering an EL-34 version with a UP on the clean channel.
I tried posting a sound clip, but the file is too large.
Steve
Blues Hound
Thanks to Taylor for the chassis, and Jelle for some great resistors, they do make a difference.
dorrisant
Post by dorrisant »
Just a question... Did you set up the FET as per Martin's guide? If not, you may want to look at that and adjust what you've got before you get rid of it. The correct bias of that transistor makes a huge difference in performance... just sayin'. If you already did that, then kindly disregard my rambling.
Blues Hound
I really don't use the FET input on my other amps with it, I know some like to use it when playing a Strat, I just run mine through the normal input.
I used to the two 9v battery method to set the bias on the FET, I believe that was from Martin, who is great guy, helped me with a Dumbleator I was building last year.
This is a great place with people who want to help you build a amp that you will enjoy playing.
Transformers are Heyboer and that PT has a 12V tap, which is really great, the OT is a Twin type with 4, 8 and 16 ohms.
Arlyn is a great guy I ordered some Dumblelator PTs from, same as Funk was using, great guy can't recommend his transformers enough.
Aaron
Post by Aaron »
Nice build! I haven't built a Bluesmaster, yet.
But I'd have to have an external OD tonestack. I couldn't help myself tweaking the trimmers all the time! :D
Aaron
