ODS Eyelet Boards
ODS Eyelet Boards
In the .pdf's below are all-eyelet versions of the ODS PCB's and preamp eyelet board TAG member JBorders had made up for sale. The dimensions and mounting centers have become the "TAG standard" to which other members have had chassis fabricated for sale. They were not designed to match any particular Dumble ODS, and there are some differences with respect to the layout drawings posted by Tony Albany.
The original intent of the eyelet board drawings was to enable a DIY replacement for the PCB and Preamp board set, with the same overall dimensions and mounting centers. The preamp board layout closely matches Dumble's ODS component layout (post-2nd Gen), so any important interactions should be preserved. Notable differences are:
  • All of the high voltage power supply filters are located on the main filter board, eliminating the need for the remotely-mounted B+4 and B+5 filter capacitors seen in some layouts.
  • The bias supply circuit has two filters, as seen in later SN amps. Refer to the #183 layout drawing for details of the B+ connections to the preamp board and the bias trimmer pot.
  • The FET board layout required some rework for eyelet construction within the same dimensions as the PCB, but it has been proven to work well.
These eyelet boards can be configured for any ODS variant, including HRM and Bluesmaster using the small HRM EQ board. Note that OD and PAB relay connections for all variants are shown for OD "on" when the OD relay coil is energized. Some original amps were configured in the opposite way.
Also included here is an alternate bipolar power supply for the SSS driver tube.
Last edited by martin manning on Sun May 26, 2024 4:25 pm, edited 35 times in total.
Re: ODS Eyelet Boards
Very nice.
dorrisant
Post by dorrisant »
Yes... Very nice. Thank you Martin.
Aaron
Post by Aaron »
Nice work Martin, thank you.
Thank you Martin.
No trouble at all. A universal relay board has been added.
dcribbs1412
Post by dcribbs1412 »
Thanks Martin
D
stelligan
Post by stelligan »
Perfect timing. Thanks :!:
stiltamp
Post by stiltamp »
Thank you very much for sharing the board layouts.
Updated with relay connections for Skyliner OD/PAB, and corrected relay diode orientation. :^)
alkuz1961
Post by alkuz1961 »
dcribbs1412
Nicely done!
Thank you!
D
stiltamp
Post by stiltamp »
Thanks to all for sharing the eylet boards and the PCB-Layouts.
amplifiednation
Post by amplifiednation »
Martin. Thank you for sharing this. The drawings are great.
Amplified Nation
www.amplifiednation.com
@ampnation
amplifiednation
I draw up the eyelet boards in CAD. If anyone wants a set, let me know I'll get some made.
Amplified Nation
@ampnation
