Rocket Speakers Suggestion
brejna
Post by brejna »
Hi, I am doing some research on Rocket speakers. So what do you suggest me to try...
Also one tip, I am in the Europe..
Cheers
Brane
redshark
Re: Rocket Speakers Suggestion
Post by redshark »
Celestion blue and Celestion G12H-55 30 watts
Both will work. Try to have your cabinet 16 ohms.
2 8 ohms in series for 16 ohms OR 4 16 ohms series-parallel.
telentubes
Post by telentubes »
2 Celestion Blues. I like The Vin 30 as well.
brejna
Post by brejna »
Thanks for the suggestions, I assume blues will break more since they 15W right?
Also what type of cab, open or closed?
sliberty
Post by sliberty »
I am big fan of transparent speakers with a Rocket. I use a 2x12 loaded with an EVM 12L and a JBL K-120. Killer sounding.
brejna
Post by brejna »
Do you have any clips recorded? It would help a lot :D
EDIT: I think I will have to spend much more money on the speakers then I thought I will!:D
Richie
Post by Richie »
There should be many clips of Rockets on youtube with various cabs and speakers. Lots of great speakers out there today to choose from.
Here are a few done with a 4x12 with greenbacks. Using different guitars. These are more cranked than clean settings..
https://www.youtube.com/watch?v=nHabPPrXe9M
https://www.youtube.com/watch?v=HHiJrufUbF0
https://www.youtube.com/watch?v=uS2vAjwOcqs
I use WGS Veteran 30 speakers with the Rocket because they have just the right amount of brightness not overboard and the price is great $79.
Yes the Celestion Alnico blue and gold are fantastic speakers but cost $289 each, even though I have two cabinets loaded with them I use with Dr Z Stangray and my own Zwreck Clone.
norburybrook
Post by norburybrook »
The rocket is a great sounding amp, very bright but not ice picky.
To be honest it sounds great through all the speakers I have, it's just a matter of taste. I would love to try it through a pair of alnico blue/gold but over here in the UK they're £200 plus each.
MC
bcat01
Post by bcat01 »
I use a tone tubby alnico & ceramic in a 2x12 - sounds fantastic!
jaysg
Post by jaysg »
The Eminence Red Fang is a 50W alnico speaker for under 200 USD. Not sure if it's a good idea for the Rocket, but it is alnico. I don't know what sort of VAT there is on imports to the EU.
brejna
Post by brejna »
Thanks for all suggestions.. This will be more complicated then I expected :D
@Richie: I like your sound very much and playing is on the top level. Did you mod your amp or?
@M Fowler: I checked WGS Veteran 30 and they are 69$ at the moment. Their price is great but shipping is around 140$ to me, without customs.
The Blue is the traditional speaker for AC30 type amps, so there's no reason it should be prone to failure, unless mods to increase the amp's power are made, eg fixed bias.
Lean Business could probably get a WGS speaker to you for a lot less than $140 http://www.lean-business.co.uk/eshop/wg ... -1907.html though the base price is higher due to UK VAT (20% sales tax), unless you are outside the EU, in which case you may be exempt from paying it.
brejna
Post by brejna »
Thanks for suggestions everyone. I was little bit to occupied with everyday life so I totally forgot about amp thing :/ These days I finally continue with research and I am thinking to buy two Vet30 or ET65/Vet30 combo..
What do you think guys?
Thank you again for all your help! Cheers
Brane
nickt
Post by nickt »
sliberty wrote:I am big fan of transparent speakers with a Rocket. I use a 2x12 loaded with an EVM 12L and a JBL K-120. Killer sounding.
Snap! Used a single K-120 for years then switched to a EVM12L - best speaker on the planet 8)
