Rocket Speakers Suggestion
Hi, I am doing some research on Rocket speakers. So what do you suggest me to try...
Also one tip, I am in the Europe..
Cheers
Brane
Cheers
Brane
Re: Rocket Speakers Suggestion
Celestion blue and Celestion G12H-55 30 watts
Both will work. Try to have your cabinet 16 ohms.
2 8 ohms in series for 16 ohms OR 4 16 ohms series-parallel.
telentubes
2 Celestion Blues. I like The Vin 30 as well.
Thanks for the suggestions, I assume blues will break more since they 15W right?
Also what type of cab, open or closed?
I am big fan of transparent speakers with a Rocket. I use a 2x12 loaded with an EVM 12L and a JBL K-120. Killer sounding.
Do you have any clips recorded? It would help a lot
EDIT: I think I will have to spend much more money on the speakers then I thought I will!:D
There should be many clips of Rockets on youtube with various cabs and speakers. Lots of great speakers out there today to choose from.
Here are a few done with a 4x12 with greenbacks. Using different guitars. These are more cranked than clean settings..
https://www.youtube.com/watch?v=nHabPPrXe9M
https://www.youtube.com/watch?v=HHiJrufUbF0
https://www.youtube.com/watch?v=uS2vAjwOcqs
I use WGS Veteran 30 speakers with the Rocket because they have just the right amount of brightness not overboard and the price is great $79.
Yes the Celestion Alnico blue and gold are fantastic speakers but cost $289 each, even though I have two cabinets loaded with them I use with Dr Z Stangray and my own Zwreck Clone.
- norburybrook
The rocket is a great sounding amp, very bright but not ice picky.
To be honest it sounds great through all the speakers I have, it's just a matter of taste. I would love to try it through a pair of alnico blue/gold but over here in the UK they're £200 plus each.
MC
MC
I use a tone tubby alnico & ceramic in a 2x12 - sounds fantastic!
The Eminence Red Fang is a 50W alnico speaker for under 200 USD. Not sure if it's a good idea for the Rocket, but it is alnico. I don't know what sort of VAT there is on imports to the EU.
Thanks for all suggestions.. This will be more complicated then I expected
@Richie: I like your sound very much and playing is on the top level. Did you mod your amp or?
@M Fowler: I checked WGS Veteran 30 and they are 69$ at the moment. Their price is great but shipping is around 140$ to me, without customs.
The Blue is the traditional speaker for AC30 type amps, so there's no reason it should be prone to failure, unless mods to increase the amp's power are made, eg fixed bias.
Lean Business could probably get a WGS speaker to you for a lot less than $140 http://www.lean-business.co.uk/eshop/wg ... -1907.html though the base price is higher due to UK VAT (20% sales tax), unless you are outside the EU, in which case you may be exempt from paying it.
Thanks for suggestions everyone. I was little bit to occupied with everyday life so I totally forgot about amp thing :/ These days I finally continue with research and I am thinking to buy two Vet30 or ET65/Vet30 combo..
What do you think guys?
Thank you again for all your help! Cheers
Brane
Brane
Snap! Used a single K-120 for years then switched to a EVM12L - best speaker on the planetsliberty wrote:I am big fan of transparent speakers with a Rocket. I use a 2x12 loaded with an EVM 12L and a JBL K-120. Killer sounding.
