Cathode Follower PA Driver question
jelle
Re: Cathode Follower PA Driver question
Post by jelle »
SSS is 12ax7.
stephenl wrote:Would this circuit also work in a cathode biased PA?
I don't think that AB2 operation would be feasible if the power tubes were cathode biased; no reason it shouldn't sound fine though.
dorrisant
Post by dorrisant »
Old thread... new question.
Would there be any problem using the CFD with a cathodyne PI? As in a Princeton AA1164?
Should be fine. The power stage is AC coupled same as it is with the LTP.
dorrisant
Post by dorrisant »
martin manning wrote: Sat Mar 01, 2025 9:09 am Should be fine. The power stage is AC coupled same as it is with the LTP.
I thought so. Thanks Martin!
