Steel String Singer#002 build from Scratch
Re: Steel String Singer#002 build from Scratch
Keep the 2x 100R faux CT or the actual CT, just connect it to the elevated DC voltage instead of grounding it.
timrobertson100
Thanks Martin
- Hendrixianer
There´s no Need for Balancing Heaters if using PT with Center Tap !!! it is already balanced!timrobertson100 wrote: ↑Sun Feb 16, 2025 4:33 pm Perhaps a daft question… you don’t use 100R balancing resistors when elevating the heaters?
DIY Amps: Marshall JTM45,Orange Grafik II 50W,Some 18W Marshalls,Dumble ODS 50W,Hiwatt DR103,Madamp G3 Blues,Dumble Steel String Singer, Fender Standalone Reverb 6G15,a few Hundred Pedals,like Uni-Vibe,etc,etc...
4 others liked this
Some people believe that even if you have a center tap on the heater winding, a better balance can be achieved with two 100-ohm resistors, or even a pot to adjust the balance. You should use either the actual CT or the resistor CT, never both.
- Hendrixianer
Than better use a wirewound Pot,called Humdinger to balance and eliminate Hum........martin manning wrote: ↑Thu Feb 27, 2025 11:47 am Some people believe that even if you have a center tap on the heater winding, a better balance can be achieved with two 100-ohm resistors, or even a pot to adjust the balance. You should use either the actual CT or the resistor CT, never both.
- Hendrixianer
Added 12V PSU and Footswitchable Fet Boost,new 2-Way Foot Switch:
- novosibir
Very nice build! Very clean! My congrats!
Just out of curiousity, what speaker(s) do you prefer with this amp?
Larry
Larry
https://www.facebook.com/profile.php?id=100057160312142
- Hendrixianer
Hi,Thanks,
I only use a 4x12 with Celestion G12H 75 Creambacks,and sounds Beutiful.
- Hendrixianer
New Faceplate added:
