Biasing AC-30 amps?
Helmholtz
Re: Biasing AC-30 amps?
Post by Helmholtz »
An aluminum chassis is a perfect heatsink on its own.
Nevertheless I'd add thermal grease.
Mark wrote: ↑Tue Jul 21, 2026 10:20 am Thanks for the advice, how does the resistors affect the performance of the amp?
It will reduce the HT power supply voltage, and hence HT current, and from that, all other voltages related to HT current.
I put a 100 ohm resistor between the valve rectifier (5AR4) and the output stage of an 5F1 Champ clone
What was your reason for doing that?
the amp didn’t sound so good when the amp distorted. I imagine it could be worse with an amp with greater wattage.
I suppose you preferred the sound of that amp with a higher voltage, hotter operating point.
However I'm not sure that can then be extrapolated to all amps.
Or why it should be even more the case with higher power amps.
What's your thinking?
Post by Mark »
Littlewyan wrote: ↑Tue Jul 21, 2026 12:52 pm It recreates the sag of a valve rectifier. Some newer Voxes use it, like the AC15C1, instead of a valve rectifier. So it’ll give a softer response which may be desirable in your case as the original AC30s had valve rectifiers.
Not sure about the Champ as Class A doesn’t sag. If you’re worried about the effect you could start smaller, 47ohm total instead of 100Ohm.
Did you measure the screen current?
I found the rail voltage of the Champ increased as signal was applied to the amp and the volume turned up. However once the amp started to distort the rail voltage would sag.
Post by Mark »
The reason was to minimise the power supply hum in class A amps by making a pi filter. The amp was quieter with the extra filtering.
In the case of the Champ, the rail voltage increases as signal increases but this only occurs till the amp distorts, then the rail voltage decreases, and the 100 ohm resistor caused a further reduction in rail voltage which made the amp sound quite mid heavy and the amp wasn’t as loud.
Roe
Post by Roe »
Littlewyan wrote: ↑Mon Jul 20, 2026 7:06 pm Ball park figure from the EL84 datasheet is 228mA total for 4 x EL84s (Screen and anode current max dissipation).
with a 50R cathode resistor, AC30s tend to draw 200ma at idle and 250ma at full power but this includes preamp (which may draw 10-12ma, depending on circuit and tubes)
Mark wrote: ↑Wed Jul 22, 2026 8:06 am ... In the case of the Champ, the rail voltage increases as signal increases but this only occurs till the amp distorts, then the rail voltage decreases, and the 100 ohm resistor caused a further reduction in rail voltage which made the amp sound quite mid heavy and the amp wasn’t as loud.
With cathode bias, every option to reduce idle dissipation will also reduce power output. Hence fixed bias became the norm for higher power amps.
And I'm not sure of the mechanism, but higher HT voltage often seems to result in a slightly brighter tone.
But I don't think the AC30 you have there will be lacking in brightness if the HT characteristics are altered to be more akin to a mid 60s model.
Roe wrote: ↑Wed Jul 22, 2026 8:09 am
As the HT voltage (and stiffness) on AC30 designs was increased through the 70s and 80s, current draw and hence idle dissipation inevitably increased too.
Littlewyan wrote: ↑Mon Jul 20, 2026 7:06 pm Depends on what's possible with the room you have or the layout.
AC side - Gives the diodes some protection if there's an inrush of current and you can split the resistance in half.
DC side - Only one resistor required but you'll need twice the wattage
... If we use resistors on the AC side we can get away with 2 x 47Ohm 5W resistors. If we go with the DC side we'll need a 15W 100Ohm resistor and unless we can panel mount it, we're getting big!
I think you might not be taking account of the high crest factor ripple currents required to charge the reservoir cap, which will significantly increase resistor dissipation.
Also current on the AC side of the rectifier is higher than in the DC side, and in the 2 phase arrangement each leg carries 0.707 of the total.
And with the 2 phase, a single resistor can be used at low voltage on the CT return to 0V common.
But this amp probably uses a non tapped winding with FWB rectifier.
As I recall I used a chassis mounted 50W 100R in the AC side for the mid 80s AC30TBR, to get the 370V HT down to a more reasonable level. A 25W resistor got hotter than I was happy with.
Roe
Post by Roe »
pdf64 wrote: ↑Wed Jul 22, 2026 10:00 am
I am not sure about this. The (collective) screen resistance was increased to 780R (instead of a choke with a 420r+ dc resistance). this may limit the current draw a bit
Helmholtz
Post by Helmholtz »
Roe wrote: ↑Wed Jul 22, 2026 2:16 pm I am not sure about this. The (collective) screen resistance was increased to 780R (instead of a choke with a 420r+ dc resistance). this may limit the current draw a bit
What schematic version are you speaking of, as this one (file:///C:/Users/User/Downloads/70s%20AC30_TBR-2.pdf) shows a 20H choke and a 20R/13W B+ dropper?
Helmholtz wrote: ↑Wed Jul 22, 2026 3:03 pm What schematic version are you speaking of, as this one (file:///C:/Users/User/Downloads/70s%20AC30_TBR-2.pdf) shows a 20H choke and a 20R/13W B+ dropper?
We can't see that file because it's on your computer.
...Steve
Helmholtz
Post by Helmholtz »
sluckey wrote: ↑Wed Jul 22, 2026 3:54 pm We can't see that file because it's on your computer.
Oh sorry, it's the pdf from the second post of this thread: https://ampgarage.com/forum/viewtopic.php?t=38103
Roe
Post by Roe »
this is the 1978-79 rose morris variant with ss rectifier and no choke
https://www.drtube.com/schematics/vox/ac30-rev.gif
Yes, but it's more of a peak current than idling. Screen grids draw a lot more peak current, when the instantaneous Vg1-k=0, than when idling, even when it's a hot idle.
This is the schematic with 780R resistance between OT CT and screen grid supply nodes
Roe wrote: ↑Wed Jul 22, 2026 6:08 pm this is the 1978-79 rose morris variant with ss rectifier and no choke
I had an amp on the bench that matched that schematic and had an "8529" chassis sticker, which I assumed to be a production date code, and pots and caps with date codes from 1980/81.
